[gdal-dev] regular grid longlat netcdf without crs meta
Even Rouault even.rouault at spatialys.com
Tue Mar 15 04:38:03 PDT 2022
Michael,
Le 15/03/2022 à 06:06, Michael Sumner a écrit :
> Hi,
> these files don't present to GDAL with a CRS, but it seems not out of
> place to assume that they can use 'oSRS.SetWellKnownGeogCS("WGS84")',
> when no other indication is found and there are dimensions 'lon,lat'
> or 'longitude,latitude'
> https://www.ncei.noaa.gov/data/sea-surface-temperature-optimum-interpolation/v2.1/access/avhrr/
> An example sds specifically:
> /vsicurl/NETCDF:"/vsicurl/https://www.ncei.noaa.gov/data/sea-surface-temperature-optimum-interpolation/v2.1/access/avhrr/202202/oisst-avhrr-v02r01.20220201.nc":sst
> Would that be reasonable? Perhaps controlled by an env var? Is there
> an established control for this I'm missing? (I'm not looking for
> '-a_srs' or VRT, I want the auto-detection to work for these and many
> other similar file sources without augmentation).
I wouldn't expose WGS84 by default, because it might be another Earth
geographic CRS, or even a non-Earth geographic CRS.
Potential solution:
- add a GDAL_NETCDF_DEFAULT_GEOGRAPHIC_CRS configuration option (that
could be set to EPSG:4326 e.g) that would be used in the situation where
the netCDF CF attributes to define a geographic CRS, but without the
actual CRS definition, are not set.
- or, more involved but more powerful, add a configuration file in data/
, let's say a netcdf_product_conf.json or whatever, where you would
define a set of product types, with matching global attributes and their
values and the corresponding CRS.
e.g (not sure my set of "matching_attributes" is appropriate for your
use case)
     "product_type": {
         "noaa_ncei_oisst": {  // the id of the product here is
completely arbitrary
             "defining_global_attributes": {
                 "title": "NOAA/NCEI 1/4 Degree Daily Optimum
Interpolation Sea Surface Temperature (OISST) Analysis, Version 2.1 -
Final",
                 "geospatial_lat_units": "degrees_north",
                 "geospatial_lon_units": "degrees_east"
             "default_values": {
                 "crs": "EPSG:4326"
- or, both the easiest and hardest one, convince the data producer to
just use the netCDF CF conventions to their full capabilities.
Even
> (It's not out of the question that I could submit a PR for this, just
> flagging discussion in case I'm missing something.)
> Thanks.
> Best, Mike
> Michael Sumner
> Software and Database Engineer
> Australian Antarctic Division
> Hobart, Australia
> e-mail: mdsumner at gmail.com
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20220315/e91acf7f/attachment.html>
