[gdal-dev] Why does ogrinfo use backtics in the output?
Even Rouault even.rouault at spatialys.com
Mon Mar 21 05:16:15 PDT 2022
Hi Jukka,
those backtics are there from day one:
https://github.com/OSGeo/gdal/commit/3359e3f9f2b1d4c1197ab14395efe652eded37da
. I suppose this is just for aesthetics. I assume this should be fine to
change that to single quotes (although some downstream consumers that
would dump ogrinfo output and do exact comparison with reference files
would probably be unhappy, but we have regularly do changes that affect
the exact output of ogrinfo through the years).  If you want to do that,
a few expected results in autotest/utilities/test_ogrinfo.py will need
to be adapted as well as
https://github.com/OSGeo/gdal/blob/master/apps/ogrinfo.cpp
Even
Le 21/03/2022 à 12:43, Rahkonen Jukka (MML) a écrit :
> Hi,
> I have been wondering for a long time why orginfo is using
> backtics/backquotes in the output. In this example before “foo” and “ESRI”
> ogrinfo foo.shp
> INFO: Open of `foo.shp'
>       using driver `ESRI Shapefile' successful.
> Not so big problem but in markup the backtick means the beginning/end
> of a code block and copy-pasting ogrinfo report may require some hand
> editing. Would it make any harm to use single quotes at both ends?
> -Jukka Rahkonen-
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20220321/7e7dacbf/attachment.html>
