[gdal-dev] Why does ogrinfo use backtics in the output?
Rahkonen Jukka (MML)
jukka.rahkonen at maanmittauslaitos.fi
Mon Mar 21 04:43:25 PDT 2022
I have been wondering for a long time why orginfo is using backtics/backquotes in the output. In this example before "foo" and "ESRI"
ogrinfo foo.shp
INFO: Open of `foo.shp'
using driver `ESRI Shapefile' successful.
Not so big problem but in markup the backtick means the beginning/end of a code block and copy-pasting ogrinfo report may require some hand editing. Would it make any harm to use single quotes at both ends?
-Jukka Rahkonen-
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20220321/8bd71f1b/attachment.html>
