[gdal-dev] GDAL 3.5.0alpha1 available
Even Rouault
even.rouault at spatialys.com
Thu Mar 24 06:46:20 PDT 2022
Bas,
given that autoconf support for GDAL will remain in 3.5.0, we can keep
things unchanged for now in frmts/grass/GNUmakefile if the driver
remains in-tree. Once autoconf support for GDAL is gone, indeed the
simplification of your patch could be done.
But the status of last discussions is that the GRASS drivers will
probably be moved in their own repository before 3.5.0.
Even
Le 24/03/2022 à 13:56, Sebastiaan Couwenberg a écrit :
> How will the gdal-grass tarball be generated?
> Will frmts/grass/GNUmakefile remain with only the dist target, e.g.
> like attached patch?
> Kind Regards,
> Bas
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
