[gdal-dev] GDAL 3.5.0alpha1 available
Even Rouault
even.rouault at spatialys.com
Mon Mar 21 11:14:20 PDT 2022
Le 21/03/2022 à 18:39, Sebastiaan Couwenberg a écrit :
> Quite a lot of new files which suggests that CPACK_SOURCE_IGNORE_FILES
> needs more work.
CPack hasn't been used at all to generate the tarball. This is the
traditionnal mkgdaldist.sh script. I suspect this comes from gdal/
content having been moved to topdir, and now things like .github/ or
doc/ are included and should probably be cleaned up. Other things you
spotted ?
| Also quite a lot of noise in the diff due $Id$ expansion changes like:
I suspect this is also due to the gdal/ moving, which must breaks the
history. That $Id$ expansion could probably be just removed.
I filed https://github.com/OSGeo/gdal/issues/5483 about those é topics
> Kind Regards,
> Bas
http://www.spatialys.com
