[gdal-dev] GDAL 3.5.0alpha1 available
Sebastiaan Couwenberg sebastic at xs4all.nl
Tue Mar 22 11:10:11 PDT 2022
On 3/21/22 19:14, Even Rouault wrote:
> Other things you spotted ?
A bunch of new data (and one ini) files, and some helper scripts like:
  frmts/grib/degrib/extract_tables.py
  frmts/grib/degrib/merge_degrib_and_wmo_tables.py
There doesn't seem to be an equivalent for:
  --with-threads
  --with-sse
  --with-ssse3
  --with-avx
The latter three seem to only be detected whether they're available at
build time, this is somewhat problematic for distribution packages where
the system building it won't be the same as the ones running it.
Also no GDAL_USE_GRASS to disable it explicitly like --with-grass=no.
Kind Regards,
Bas
  GPG Key ID: 4096R/6750F10AE88D4AF1
Fingerprint: 8182 DE41 7056 408D 6146  50D1 6750 F10A E88D 4AF1
