[gdal-dev] GDAL 3.5.0alpha1 available
Even Rouault
even.rouault at spatialys.com
Mon Mar 21 12:35:56 PDT 2022
Forgot to mention that the GDAL specific options to control the CMake
build are documented in https://gdal.org/build_hints.html (of course
general CMake variables that control builds, like the ones listed at
https://cmake.org/cmake/help/latest/manual/cmake-variables.7.html, can
also generally be used)
Practical examples of build recipees as used by CI can be found in
https://github.com/OSGeo/gdal/blob/master/.github/workflows/cmake_builds.yml
and
https://github.com/OSGeo/gdal/blob/master/.github/workflows/android_cmake/start.sh
(although for the later this is probably done in the most idiomatic way
to cross-compile for Android)
Even
Le 21/03/2022 à 00:05, Even Rouault a écrit :
> Hi,
> As discussed a few weeks ago, here's a GDAL 3.5.0alpha1 snapshot,
> mostly for the sake of exercising the new CMake build system (thanks
> to all early testers and contributors!). The libtool numbers have
> *not* been updated (I believe they are still the same as the 3.3.0
> release). This is not meant as being pushed to any distribution
> channel yet.
> Download links:
> http://download.osgeo.org/gdal/3.5.0/gdal-3.5.0alpha1.tar.gz
> http://download.osgeo.org/gdal/3.5.0/gdal-3.5.0alpha1.tar.xz
> http://download.osgeo.org/gdal/3.5.0/gdal350alpha1.zip
> Even
http://www.spatialys.com
