[gdal-dev] Memory allocation issues on Android 11+ and scudo
Greg Troxel gdt at lexort.com
Mon Mar 28 06:16:30 PDT 2022
Philippe Lelong <lelong.ph at meltemus.com> writes:
> What I can see is that the memory grows exponentially until no more
> memory is available and crash, even on systems with huge memory
> available while an Android device without SCUDO and very limited
> memory (let's say 4Gb) in the same exact conditions, with the same
> apk, runs perfectly. The logcat command show this:
You said "exponentially" but you didn't attach a graph of usage, so I
have no idea if you really mean exponentially and what exponent :-)
I also can't tell what "huge memory" means and if that's android or not.
You didn't give the build recipe; I'm assuming this is inside an apk
using NDK, but it could be within termux.
> 03-28 12:40:34.255  4959  5005 W libc    : malloc(264196) failed: returning null pointer
> 03-28 12:40:34.256  4959  5005 W libc    : malloc(264196) failed: returning null pointer
> 03-28 12:40:34.612   630   630 D io_stats: !@ Write_top(KB): kworker/u16:1(32583) 8
> 03-28 12:40:34.820  4959  5041 I scudo   : Scudo ERROR: out of memory trying to allocate 64 bytes
> 03-28 12:40:34.820  4959  5042 I scudo   : Scudo ERROR: out of memory trying to allocate 64 bytes
> 03-28 12:40:34.820  4959  5033 I scudo   : Scudo ERROR: out of memory trying to allocate 64 bytes
> 03-28 12:40:34.820  4959  5031 I scudo   : Scudo ERROR: out of memory trying to allocate 64 bytes
> 03-28 12:40:34.820  4959  5038 I scudo   : Scudo ERROR: out of memory trying to allocate 64 bytes
> 03-28 12:40:34.820  4959  5040 I scudo   : Scudo ERROR: out of memory trying to allocate 64 bytes
It seems obvious that you should use some kind of malloc debugging that
has a trace of malloc/free to a log and then postprocess it.
Keep in mind that the bug could be in this other allocator.  I'm not
saying it's likely, just that it's best not to make assumptions.
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20220328/da734496/attachment.sig>
