[gdal-dev] Memory allocation issues on Android 11+ and scudo
Even Rouault
even.rouault at spatialys.com
Mon Mar 28 06:24:02 PDT 2022
didn't hear about Scudo before, but it seems it is a LLVM side project:
https://llvm.org/docs/ScudoHardenedAllocator.html
So perhaps you could build and use it on Linux as shown in
https://llvm.org/docs/ScudoHardenedAllocator.html#library
Besides a potential bug in the allocator, it might be that the S57
driver has a memory allocation pattern that doesn't please Scudo.
Assuming that the problematic memory allocations are done using GDAL's
VSIMalloc() (and not C++ new/delete), then have a look at the various
#define that you can set at the top of port/cpl_vsisimple.cpp and can be
used to trace memory allocations
// Uncomment to check consistent usage of VSIMalloc(), VSIRealloc(),
// VSICalloc(), VSIFree(), VSIStrdup().
// #define DEBUG_VSIMALLOC
// Uncomment to compute memory usage statistics.
// DEBUG_VSIMALLOC must also be defined.
// #define DEBUG_VSIMALLOC_STATS
// Uncomment to print every memory allocation or deallocation.
// #define DEBUG_VSIMALLOC_VERBOSE
// Number of bytes of the malloc/calloc/free that triggers a debug trace.
// Can be 0 for all allocs.
#define THRESHOLD_PRINT 10000
Even
Le 28/03/2022 à 14:58, Philippe Lelong a écrit :
> Hi,
> I am searching for this issue for months now, and cannot find any
> solution.
> To make a long story short, we are using GDAL to decode OGR/S57 charts
> for years now. We are facing numerous crashes under Android 11 and up
> if and only if this Android 11 implementation is using SCUDO as a
> memory allocator (if jemalloc is used no problems). We face this
> problem with an old GDAL2.1.3 version, so we updated to GDAL 3.4.1 but
> the issue is the same.
> What I can see is that the memory grows exponentially until no more
> memory is available and crash, even on systems with huge memory
> available while an Android device without SCUDO and very limited
> memory (let's say 4Gb) in the same exact conditions, with the same
> apk, runs perfectly. The logcat command show this:
> 03-28 12:40:34.255 4959 5005 W libc : malloc(264196) failed:
> returning null pointer
> 03-28 12:40:34.256 4959 5005 W libc : malloc(264196) failed:
> 03-28 12:40:34.612 630 630 D io_stats: !@ Write_top(KB):
> kworker/u16:1(32583) 8
> 03-28 12:40:34.820 4959 5041 I scudo : Scudo ERROR: out of memory
> trying to allocate 64 bytes
> 03-28 12:40:34.820 4959 5042 I scudo : Scudo ERROR: out of memory
> 03-28 12:40:34.820 4959 5033 I scudo : Scudo ERROR: out of memory
> 03-28 12:40:34.820 4959 5031 I scudo : Scudo ERROR: out of memory
> 03-28 12:40:34.820 4959 5038 I scudo : Scudo ERROR: out of memory
> 03-28 12:40:34.820 4959 5040 I scudo : Scudo ERROR: out of memory
> and then crash
> Any help on how to debug and eventually fix this would be highly
> appreciated.
> Best regards,
> Philippe from qtVlm development team.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20220328/7b5f56e9/attachment.html>
