[gdal-dev] Memory allocation issues on Android 11+ and scudo
Philippe Lelong
lelong.ph at meltemus.com
Mon Mar 28 06:50:13 PDT 2022
Thanks Even and Greg for your fast replies
The app and GDAL are built with Android NDK 21 (I have tried NDK 30 and 31) and is targeting SDK 30. High memory Android device is 10Gb or even 14Gb with RAM PLUS. I can add that the app itself is based on Qt 5.15.8 and runs fine on Windows, Linux, Raspberry 2/3/4 32bits or 64bits, MacOS, iOS and Android without Scudo. It is heavily multithreaded including during GDAL calls.
I can also add that I have tried a 32bits build (armv7) running on these armV8 devices, same problem, although the messages in logcat are a bit different. I can also say that I am 99.9% sure this is triggered by GDAL, because our same exactly S52/57 module reading other formats without GDAL does not crash.
I have seen these debug defines in cpl_simple.cpp. I will enable them, rebuild and report here. I don't have a scudo device apart from a emulated one but it is x86-64 and it does not seem to behave exactly the same as the users' ARM64 bits (Samsung S21). My feeling is that it is connected to ARM 64 architecture.
Thanks again, more later hopefully.
Philippe.
Sent: Monday, March 28, 2022 3:24 PM
To: Philippe Lelong; gdal-dev at lists.osgeo.org
Subject: Re: [gdal-dev] Memory allocation issues on Android 11+ and scudo
didn't hear about Scudo before, but it seems it is a LLVM side project: https://llvm.org/docs/ScudoHardenedAllocator.html
So perhaps you could build and use it on Linux as shown in https://llvm.org/docs/ScudoHardenedAllocator.html#library
Besides a potential bug in the allocator, it might be that the S57 driver has a memory allocation pattern that doesn't please Scudo.
Assuming that the problematic memory allocations are done using GDAL's VSIMalloc() (and not C++ new/delete), then have a look at the various #define that you can set at the top of port/cpl_vsisimple.cpp and can be used to trace memory allocations
// Uncomment to check consistent usage of VSIMalloc(), VSIRealloc(),
// VSICalloc(), VSIFree(), VSIStrdup().
// #define DEBUG_VSIMALLOC
// Uncomment to compute memory usage statistics.
// DEBUG_VSIMALLOC must also be defined.
// #define DEBUG_VSIMALLOC_STATS
// Uncomment to print every memory allocation or deallocation.
// #define DEBUG_VSIMALLOC_VERBOSE
// Number of bytes of the malloc/calloc/free that triggers a debug trace.
// Can be 0 for all allocs.
#define THRESHOLD_PRINT 10000
Even
Le 28/03/2022 à 14:58, Philippe Lelong a écrit :
I am searching for this issue for months now, and cannot find any solution.
To make a long story short, we are using GDAL to decode OGR/S57 charts for years now. We are facing numerous crashes under Android 11 and up if and only if this Android 11 implementation is using SCUDO as a memory allocator (if jemalloc is used no problems). We face this problem with an old GDAL2.1.3 version, so we updated to GDAL 3.4.1 but the issue is the same.
What I can see is that the memory grows exponentially until no more memory is available and crash, even on systems with huge memory available while an Android device without SCUDO and very limited memory (let's say 4Gb) in the same exact conditions, with the same apk, runs perfectly. The logcat command show this:
03-28 12:40:34.255 4959 5005 W libc : malloc(264196) failed: returning null pointer
03-28 12:40:34.256 4959 5005 W libc : malloc(264196) failed: returning null pointer
03-28 12:40:34.612 630 630 D io_stats: !@ Write_top(KB): kworker/u16:1(32583) 8
03-28 12:40:34.820 4959 5041 I scudo : Scudo ERROR: out of memory trying to allocate 64 bytes
03-28 12:40:34.820 4959 5042 I scudo : Scudo ERROR: out of memory trying to allocate 64 bytes
03-28 12:40:34.820 4959 5033 I scudo : Scudo ERROR: out of memory trying to allocate 64 bytes
03-28 12:40:34.820 4959 5031 I scudo : Scudo ERROR: out of memory trying to allocate 64 bytes
03-28 12:40:34.820 4959 5038 I scudo : Scudo ERROR: out of memory trying to allocate 64 bytes
03-28 12:40:34.820 4959 5040 I scudo : Scudo ERROR: out of memory trying to allocate 64 bytes
and then crash
Any help on how to debug and eventually fix this would be highly appreciated.
Best regards,
Philippe from qtVlm development team.
gdal-dev mailing list
gdal-dev at lists.osgeo.org<mailto:gdal-dev at lists.osgeo.org>
https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20220328/ba0ddf0a/attachment-0001.html>
