[gdal-dev] GDAL 3.5.0rc3 available (Re: GDAL 3.5.0 release candidate available)
Even Rouault
even.rouault at spatialys.com
Mon May 9 12:30:14 PDT 2022
Sean,
I've issue a rc3 with a fix for that issue:
https://download.osgeo.org/gdal/3.5.0/gdal-3.5.0rc3.tar.xz
https://download.osgeo.org/gdal/3.5.0/gdal-3.5.0rc3.tar.gz
https://download.osgeo.org/gdal/3.5.0/gdal350rc3.zip
Even
Le 09/05/2022 à 20:47, Sean Gillies a écrit :
> Hi Even,
> I'm still using the legacy configure script and have found that
> ogrmvtdataset.cpp doesn't compile on my system due to
> In file included from ogrmvtdataset.cpp:43:
> .../ogr_geos.h:40:12: fatal error: geos_c.h: No such file or directory
> This is GDAL 3.5.0rc2. I haven't tried the earlier pre-releases. GDAL
> 3.4.3 compiled and installed on the same computer using the same
> script, which is:
> LD_LIBRARY_PATH=/home/seangillies/local/lib ./configure
> --prefix=/home/seangillies/local --with-curl
> --with-geos=/home/seangillies/local/bin/geos-config
> --with-proj=/home/seangillies/local
> On Mon, May 9, 2022 at 3:48 AM Even Rouault
> <even.rouault at spatialys.com> wrote:
> Hi,
> I've issued a RC2 with the following changes:
> - CMake: fix build of NITF driver if rebuilding after disabling
> JPEG driver
> - port/cpl_recode_iconv.cpp: fix invalid cast error with uclibc
> (#5684)
> - PNG: report cause when unable to create file
> - PCIDSK: fix build on 32-bit architectures on Debian (fixes #5694)
> - TileDB: compiler warning fix on 32bit
> - ogr2ogr: avoid potential nullptr deref (CID 1488679)
> - netCDF: add support for writing/reading geolocation array without a
> grid_mapping variable
> Updated archives:
> https://download.osgeo.org/gdal/3.5.0/gdal-3.5.0rc2.tar.xz
> https://download.osgeo.org/gdal/3.5.0/gdal-3.5.0rc2.tar.gz
> https://download.osgeo.org/gdal/3.5.0/gdal350rc2.zip
> https://download.osgeo.org/gdal/3.5.0/gdalautotest-3.5.0rc2.tar.gz
> https://download.osgeo.org/gdal/3.5.0/gdalautotest-3.5.0rc2.zip
> Even
> Le 06/05/2022 à 15:06, Even Rouault a écrit :
> > Hi,
> > I have prepared a GDAL/OGR 3.5.0 release candidate.
> > NEWS at:
> > https://github.com/OSGeo/gdal/blob/v3.5.0RC1/NEWS.md
> > Note the first item about the new CMake build system, and the
> > deprecation of the autoconf & nmake build systems that will be
> removed
> > in GDAL 3.6.0
> > Pick up an archive among the following ones (by ascending size):
> > https://download.osgeo.org/gdal/3.5.0/gdal-3.5.0rc1.tar.xz
> > https://download.osgeo.org/gdal/3.5.0/gdal-3.5.0rc1.tar.gz
> > https://download.osgeo.org/gdal/3.5.0/gdal350rc1.zip
> > A snapshot of the gdalautotest suite is also available :
> > https://download.osgeo.org/gdal/3.5.0/gdalautotest-3.5.0rc1.tar.gz
> > https://download.osgeo.org/gdal/3.5.0/gdalautotest-3.5.0rc1.zip
> > A snapshot of the documentation is at:
> > https://download.osgeo.org/gdal/3.5.0/gdal350doc.zip
> > The GDAL-GRASS plugin sources and release process has been moved to
> > https://github.com/OSGeo/gdal-grass
> > I'll call for a vote promoting it to next week if no serious
> problems
> > are reported before.
> > The "release/3.5" branch has been created for all bug fixes
> related to
> > 3.5.x. master is now targetting 3.6.0dev.
> > Best regards,
> > Even
> Sean Gillies
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20220509/176c1de3/attachment.htm>
