[gdal-dev] GDAL 3.5.0rc3 available (Re: GDAL 3.5.0 release candidate available)
Sean Gillies
sean.gillies at gmail.com
Mon May 9 15:27:26 PDT 2022
Thanks, Even. RC3 compiles and I don't see any regressions from rasterio's
perspective. Looking forward to the new release!
On Mon, May 9, 2022 at 1:30 PM Even Rouault <even.rouault at spatialys.com>
wrote:
> Sean,
> I've issue a rc3 with a fix for that issue:
> https://download.osgeo.org/gdal/3.5.0/gdal-3.5.0rc3.tar.xz
> https://download.osgeo.org/gdal/3.5.0/gdal-3.5.0rc3.tar.gz
> https://download.osgeo.org/gdal/3.5.0/gdal350rc3.zip
> Even
> Le 09/05/2022 à 20:47, Sean Gillies a écrit :
> Hi Even,
> I'm still using the legacy configure script and have found that
> ogrmvtdataset.cpp doesn't compile on my system due to
> In file included from ogrmvtdataset.cpp:43:
> .../ogr_geos.h:40:12: fatal error: geos_c.h: No such file or directory
> This is GDAL 3.5.0rc2. I haven't tried the earlier pre-releases. GDAL
> 3.4.3 compiled and installed on the same computer using the same script,
> which is:
> LD_LIBRARY_PATH=/home/seangillies/local/lib ./configure
> --prefix=/home/seangillies/local --with-curl
> --with-geos=/home/seangillies/local/bin/geos-config
> --with-proj=/home/seangillies/local
> On Mon, May 9, 2022 at 3:48 AM Even Rouault <even.rouault at spatialys.com>
> wrote:
>> Hi,
>> I've issued a RC2 with the following changes:
>> - CMake: fix build of NITF driver if rebuilding after disabling JPEG
>> driver
>> - port/cpl_recode_iconv.cpp: fix invalid cast error with uclibc (#5684)
>> - PNG: report cause when unable to create file
>> - PCIDSK: fix build on 32-bit architectures on Debian (fixes #5694)
>> - TileDB: compiler warning fix on 32bit
>> - ogr2ogr: avoid potential nullptr deref (CID 1488679)
>> - netCDF: add support for writing/reading geolocation array without a
>> grid_mapping variable
>> Updated archives:
>> https://download.osgeo.org/gdal/3.5.0/gdal-3.5.0rc2.tar.xz
>> https://download.osgeo.org/gdal/3.5.0/gdal-3.5.0rc2.tar.gz
>> https://download.osgeo.org/gdal/3.5.0/gdal350rc2.zip
>> https://download.osgeo.org/gdal/3.5.0/gdalautotest-3.5.0rc2.tar.gz
>> https://download.osgeo.org/gdal/3.5.0/gdalautotest-3.5.0rc2.zip
>> Even
>> Le 06/05/2022 à 15:06, Even Rouault a écrit :
>> > Hi,
>> > I have prepared a GDAL/OGR 3.5.0 release candidate.
>> > NEWS at:
>> > https://github.com/OSGeo/gdal/blob/v3.5.0RC1/NEWS.md
>> > Note the first item about the new CMake build system, and the
>> > deprecation of the autoconf & nmake build systems that will be removed
>> > in GDAL 3.6.0
>> > Pick up an archive among the following ones (by ascending size):
>> > https://download.osgeo.org/gdal/3.5.0/gdal-3.5.0rc1.tar.xz
>> > https://download.osgeo.org/gdal/3.5.0/gdal-3.5.0rc1.tar.gz
>> > https://download.osgeo.org/gdal/3.5.0/gdal350rc1.zip
>> > A snapshot of the gdalautotest suite is also available :
>> > https://download.osgeo.org/gdal/3.5.0/gdalautotest-3.5.0rc1.tar.gz
>> > https://download.osgeo.org/gdal/3.5.0/gdalautotest-3.5.0rc1.zip
>> > A snapshot of the documentation is at:
>> > https://download.osgeo.org/gdal/3.5.0/gdal350doc.zip
>> > The GDAL-GRASS plugin sources and release process has been moved to
>> > https://github.com/OSGeo/gdal-grass
>> > I'll call for a vote promoting it to next week if no serious problems
>> > are reported before.
>> > The "release/3.5" branch has been created for all bug fixes related to
>> > 3.5.x. master is now targetting 3.6.0dev.
>> > Best regards,
>> > Even
Sean Gillies
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20220509/818623ba/attachment.htm>
