[gdal-dev] GDAL 3.5.0rc3 available (Re: GDAL 3.5.0 release candidate available)
Sandro Mani manisandro at gmail.com
Tue May 10 02:48:29 PDT 2022
Hi
Testing RC3 on Fedora rawhide, the native build with cmake build fine.
The mingw build OTOH fails with
/home/sandro/rpmbuild/BUILD/gdal-3.5.0-fedora/port/cpl_vsil_s3.cpp:4556:29:
error: invalid user-defined conversion from 'const
cpl::IVSIS3LikeFSHandler::Sync(const char*, const char*, const char*
const*, GDALProgressFunc, void*,
char***)::<lambda(void*)>::<lambda(double, const char*, void*)>' to
'GDALProgressFunc' {aka 'int (__attribute__((stdcall)) *)(double, const
char*, void*)'} [-fpermissive]
  4556 |                             progressFunc, &progressData) )
/home/sandro/rpmbuild/BUILD/gdal-3.5.0-fedora/port/cpl_vsil_s3.cpp:4473:39:
note: candidate is: 'cpl::IVSIS3LikeFSHandler::Sync(const char*, const
char*, const char* const*, GDALProgressFunc, void*,
void*)>::operator int (*)(double, const char*, void*)() const' (near match)
  4473 |             const auto progressFunc = [](double pct, const
char*, void* pProgressDataIn)
note:   no known conversion from 'int (*)(double, const char*, void*)'
to 'GDALProgressFunc' {aka 'int (__attribute__((stdcall)) *)(double,
const char*, void*)'}
/home/sandro/rpmbuild/BUILD/gdal-3.5.0-fedora/port/cpl_vsil_s3.cpp:3529:39:
note:   initializing argument 6 of 'bool
cpl::IVSIS3LikeFSHandler::CopyFileA(VSILFILE*, vsi_l_offset, const
char*, const char*, CSLConstList, GDALProgressFunc, void*)'
  3529 |                      GDALProgressFunc pProgressFunc,
make[2]: *** [port/CMakeFiles/cpl.dir/build.make:1010:
port/CMakeFiles/cpl.dir/cpl_vsil_s3.cpp.obj] Error 1
make[2]: Leaving directory
'/home/sandro/rpmbuild/BUILD/gdal-3.5.0-fedora/build_win32'
make[2]: *** Waiting for unfinished jobs....
make[2]: Entering directory
I'm investigating.
Thanks
Sandro
On 10.05.22 00:27, Sean Gillies wrote:
> Thanks, Even. RC3 compiles and I don't see any regressions from
> rasterio's perspective. Looking forward to the new release!
> On Mon, May 9, 2022 at 1:30 PM Even Rouault
> <even.rouault at spatialys.com> wrote:
>     Sean,
>     I've issue a rc3 with a fix for that issue:
>     https://download.osgeo.org/gdal/3.5.0/gdal-3.5.0rc3.tar.xz
>     https://download.osgeo.org/gdal/3.5.0/gdal-3.5.0rc3.tar.gz
>     https://download.osgeo.org/gdal/3.5.0/gdal350rc3.zip
>     Even
>     Le 09/05/2022 à 20:47, Sean Gillies a écrit :
>>     Hi Even,
>>     I'm still using the legacy configure script and have found that
>>     ogrmvtdataset.cpp doesn't compile on my system due to
>>     In file included from ogrmvtdataset.cpp:43:
>>     .../ogr_geos.h:40:12: fatal error: geos_c.h: No such file or
>>     directory
>>     This is GDAL 3.5.0rc2. I haven't tried the earlier pre-releases.
>>     GDAL 3.4.3 compiled and installed on the same computer using the
>>     same script, which is:
>>     LD_LIBRARY_PATH=/home/seangillies/local/lib ./configure
>>     --prefix=/home/seangillies/local --with-curl
>>     --with-geos=/home/seangillies/local/bin/geos-config
>>     --with-proj=/home/seangillies/local
>>     On Mon, May 9, 2022 at 3:48 AM Even Rouault
>>         Hi,
>>         I've issued a RC2 with the following changes:
>>         - CMake: fix build of NITF driver if rebuilding after
>>         disabling JPEG driver
>>         - port/cpl_recode_iconv.cpp: fix invalid cast error with
>>         uclibc (#5684)
>>         - PNG: report cause when unable to create file
>>         - PCIDSK: fix build on 32-bit architectures on Debian (fixes
>>         #5694)
>>         - TileDB: compiler warning fix on 32bit
>>         - ogr2ogr: avoid potential nullptr deref (CID 1488679)
>>         - netCDF: add support for writing/reading geolocation array
>>         without a
>>         grid_mapping variable
>>         Updated archives:
>>         https://download.osgeo.org/gdal/3.5.0/gdal-3.5.0rc2.tar.xz
>>         https://download.osgeo.org/gdal/3.5.0/gdal-3.5.0rc2.tar.gz
>>         https://download.osgeo.org/gdal/3.5.0/gdal350rc2.zip
>>         https://download.osgeo.org/gdal/3.5.0/gdalautotest-3.5.0rc2.tar.gz
>>         https://download.osgeo.org/gdal/3.5.0/gdalautotest-3.5.0rc2.zip
>>         Even
>>         Le 06/05/2022 à 15:06, Even Rouault a écrit :
>>         > Hi,
>>         > I have prepared a GDAL/OGR 3.5.0 release candidate.
>>         > NEWS at:
>>         > https://github.com/OSGeo/gdal/blob/v3.5.0RC1/NEWS.md
>>         > Note the first item about the new CMake build system, and the
>>         > deprecation of the autoconf & nmake build systems that will
>>         be removed
>>         > in GDAL 3.6.0
>>         > Pick up an archive among the following ones (by ascending
>>         size):
>>         > https://download.osgeo.org/gdal/3.5.0/gdal-3.5.0rc1.tar.xz
>>         > https://download.osgeo.org/gdal/3.5.0/gdal-3.5.0rc1.tar.gz
>>         > https://download.osgeo.org/gdal/3.5.0/gdal350rc1.zip
>>         > A snapshot of the gdalautotest suite is also available :
>>         https://download.osgeo.org/gdal/3.5.0/gdalautotest-3.5.0rc1.tar.gz
>>         > https://download.osgeo.org/gdal/3.5.0/gdalautotest-3.5.0rc1.zip
>>         > A snapshot of the documentation is at:
>>         > https://download.osgeo.org/gdal/3.5.0/gdal350doc.zip
>>         > The GDAL-GRASS plugin sources and release process has been
>>         moved to
>>         > https://github.com/OSGeo/gdal-grass
>>         > I'll call for a vote promoting it to next week if no
>>         serious problems
>>         > are reported before.
>>         > The "release/3.5" branch has been created for all bug fixes
>>         related to
>>         > 3.5.x. master is now targetting 3.6.0dev.
>>         > Best regards,
>>         > Even
> Sean Gillies
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20220510/c4030bc9/attachment-0001.htm>
