[gdal-dev] GDAL 3.5.0rc4 available (Re: GDAL 3.5.0 release candidate available)
Even Rouault
even.rouault at spatialys.com
Tue May 10 14:33:43 PDT 2022
Sean,
So your issue is with a GDAL autoconf build. I can't see any significant
changes in configure.ac between GDAL 3.5.0 and 3.4.0 related to rpath.
This has probably not changed in years. I do see in your logs that the
linking line of GDAL has a
-rpath /usr/local/lib
and that there's a /usr/local/lib/libproj.25.dylib file
But perhaps the issue is more with the PROJ CMake build (hypothesis that
you could check by testing with a PROJ 8.2.1 autoconf build) ? I don't
know... Mac + rpath is hostile territory for me.
Does running a GDAL binary, like gdalinfo, works before using that
delocate module ?
Yes 5413 is CMake specific.
Even
Le 10/05/2022 à 23:02, Sean Gillies a écrit :.
> Hi Even,
> I'm running into a problem with GDAL 3.5.0rc4 and PROJ 9.0.0 on macos.
> It occurs when I use https://github.com/matthew-brett/delocate to
> relocate GDAL and its dependencies into rasterio wheels.
> The error:
> ERROR:delocate.libsana:
> @rpath/libproj.25.dylib not found:
> Needed by: /usr/local/lib/libgdal.31.dylib
> Search path:
> ERROR:delocate.libsana:@rpath/libproj.25.dylib not found, requested by
> Here is its context:
> https://github.com/rasterio/rasterio-wheels/runs/6375882173?check_suite_focus=true#step:4:4025.
> I searched the GDAL tracker for related issues and only found
> https://github.com/OSGeo/gdal/issues/5413. It looks like it could be
> related, but it also looks like the fix is cmake specific and isn't
> available for autotools builds. Is that correct?
> On Tue, May 10, 2022 at 8:13 AM Even Rouault
> <even.rouault at spatialys.com> wrote:
> Hi,
> I've issued a rc4 with the following fixes w.r.t rc3:
> * fix build error with CMake >= 3.10.2 and < 3.11
> * fix build errors with Fedora mingw32
> Updated archives:
> https://download.osgeo.org/gdal/3.5.0/gdal-3.5.0rc4.tar.xz
> https://download.osgeo.org/gdal/3.5.0/gdal-3.5.0rc4.tar.gz
> https://download.osgeo.org/gdal/3.5.0/gdal350rc4.zip
> Even
> Le 06/05/2022 à 15:06, Even Rouault a écrit :
> > Hi,
> > I have prepared a GDAL/OGR 3.5.0 release candidate.
> > NEWS at:
> > https://github.com/OSGeo/gdal/blob/v3.5.0RC1/NEWS.md
> > Note the first item about the new CMake build system, and the
> > deprecation of the autoconf & nmake build systems that will be
> removed
> > in GDAL 3.6.0
> > Pick up an archive among the following ones (by ascending size):
> > https://download.osgeo.org/gdal/3.5.0/gdal-3.5.0rc1.tar.xz
> > https://download.osgeo.org/gdal/3.5.0/gdal-3.5.0rc1.tar.gz
> > https://download.osgeo.org/gdal/3.5.0/gdal350rc1.zip
> > A snapshot of the gdalautotest suite is also available :
> > https://download.osgeo.org/gdal/3.5.0/gdalautotest-3.5.0rc1.tar.gz
> > https://download.osgeo.org/gdal/3.5.0/gdalautotest-3.5.0rc1.zip
> > A snapshot of the documentation is at:
> > https://download.osgeo.org/gdal/3.5.0/gdal350doc.zip
> > The GDAL-GRASS plugin sources and release process has been moved to
> > https://github.com/OSGeo/gdal-grass
> > I'll call for a vote promoting it to next week if no serious
> problems
> > are reported before.
> > The "release/3.5" branch has been created for all bug fixes
> related to
> > 3.5.x. master is now targetting 3.6.0dev.
> > Best regards,
> > Even
> http://www.spatialys.com
> My software is free, but my time generally not.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
> Sean Gillies
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20220510/32ee693e/attachment-0001.htm>
