[gdal-dev] GDAL 3.5.0rc4 available (Re: GDAL 3.5.0 release candidate available)
Alan Snow
alansnow21 at gmail.com
Tue May 10 15:04:57 PDT 2022
This might be a helpful reference:
https://github.com/pyproj4/pyproj-wheels/issues/45
On Tue, May 10, 2022, 4:33 PM Even Rouault <even.rouault at spatialys.com>
wrote:
> Sean,
> So your issue is with a GDAL autoconf build. I can't see any significant
> changes in configure.ac between GDAL 3.5.0 and 3.4.0 related to rpath.
> This has probably not changed in years. I do see in your logs that the
> linking line of GDAL has a
> -rpath /usr/local/lib
> and that there's a /usr/local/lib/libproj.25.dylib file
> But perhaps the issue is more with the PROJ CMake build (hypothesis that
> you could check by testing with a PROJ 8.2.1 autoconf build) ? I don't
> know... Mac + rpath is hostile territory for me.
> Does running a GDAL binary, like gdalinfo, works before using that
> delocate module ?
> Yes 5413 is CMake specific.
> Even
> Le 10/05/2022 à 23:02, Sean Gillies a écrit :.
> Hi Even,
> I'm running into a problem with GDAL 3.5.0rc4 and PROJ 9.0.0 on macos. It
> occurs when I use https://github.com/matthew-brett/delocate to relocate
> GDAL and its dependencies into rasterio wheels.
> The error:
> ERROR:delocate.libsana:
> @rpath/libproj.25.dylib not found:
> Needed by: /usr/local/lib/libgdal.31.dylib
> Search path:
> ERROR:delocate.libsana:@rpath/libproj.25.dylib not found, requested by
> Here is its context:
> https://github.com/rasterio/rasterio-wheels/runs/6375882173?check_suite_focus=true#step:4:4025
> I searched the GDAL tracker for related issues and only found
> https://github.com/OSGeo/gdal/issues/5413. It looks like it could be
> related, but it also looks like the fix is cmake specific and isn't
> available for autotools builds. Is that correct?
> On Tue, May 10, 2022 at 8:13 AM Even Rouault <even.rouault at spatialys.com>
> wrote:
>> Hi,
>> I've issued a rc4 with the following fixes w.r.t rc3:
>> * fix build error with CMake >= 3.10.2 and < 3.11
>> * fix build errors with Fedora mingw32
>> Updated archives:
>> https://download.osgeo.org/gdal/3.5.0/gdal-3.5.0rc4.tar.xz
>> https://download.osgeo.org/gdal/3.5.0/gdal-3.5.0rc4.tar.gz
>> https://download.osgeo.org/gdal/3.5.0/gdal350rc4.zip
>> Even
>> Le 06/05/2022 à 15:06, Even Rouault a écrit :
>> > Hi,
>> > I have prepared a GDAL/OGR 3.5.0 release candidate.
>> > NEWS at:
>> > https://github.com/OSGeo/gdal/blob/v3.5.0RC1/NEWS.md
>> > Note the first item about the new CMake build system, and the
>> > deprecation of the autoconf & nmake build systems that will be removed
>> > in GDAL 3.6.0
>> > Pick up an archive among the following ones (by ascending size):
>> > https://download.osgeo.org/gdal/3.5.0/gdal-3.5.0rc1.tar.xz
>> > https://download.osgeo.org/gdal/3.5.0/gdal-3.5.0rc1.tar.gz
>> > https://download.osgeo.org/gdal/3.5.0/gdal350rc1.zip
>> > A snapshot of the gdalautotest suite is also available :
>> > https://download.osgeo.org/gdal/3.5.0/gdalautotest-3.5.0rc1.tar.gz
>> > https://download.osgeo.org/gdal/3.5.0/gdalautotest-3.5.0rc1.zip
>> > A snapshot of the documentation is at:
>> > https://download.osgeo.org/gdal/3.5.0/gdal350doc.zip
>> > The GDAL-GRASS plugin sources and release process has been moved to
>> > https://github.com/OSGeo/gdal-grass
>> > I'll call for a vote promoting it to next week if no serious problems
>> > are reported before.
>> > The "release/3.5" branch has been created for all bug fixes related to
>> > 3.5.x. master is now targetting 3.6.0dev.
>> > Best regards,
>> > Even
>> http://www.spatialys.com
>> My software is free, but my time generally not.
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/gdal-dev
> Sean Gillies
> gdal-dev mailing listgdal-dev at lists.osgeo.orghttps://lists.osgeo.org/mailman/listinfo/gdal-dev
> -- http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20220510/4864859d/attachment.htm>
