[gdal-dev] CMake Error at ....../GDAL/cmake/helpers/generate_gdal_version_h.cmake:27 (string): string sub-command SUBSTRING requires four arguments.
Even Rouault
even.rouault at spatialys.com
Wed May 11 13:09:08 PDT 2022
This is the 3rd time in a few days you post the same message, with
factually incorrect elements (GDAL 3.4.3 doesn't have CMake support) as
I already pointed out. Please don't do it a 4th time.
Try with the 3.5.0 rc4 sources:
https://download.osgeo.org/gdal/3.5.0/gdal-3.5.0rc4.tar.gz
Even
Le 11/05/2022 à 21:26, Pei JIA a écrit :
> Hi, all:
> I successfully configured and built gdal-3.4.3, but failed to install
> it on Ubuntu 22.04, with gcc-11.2,
> /➜ ~ uname -r
> 5.15.0-27-generic
> ➜ ~ lsb_release -a
> No LSB modules are available.
> Distributor ID: Ubuntu
> Description: Ubuntu 22.04 LTS
> Release: 22.04
> Codename: jammy
> ➜ ~ gcc --version
> gcc (Ubuntu 11.2.0-19ubuntu1) 11.2.0
> Copyright (C) 2021 Free Software Foundation, Inc.
> This is free software; see the source for copying conditions. There is NO
> warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR
> PURPOSE./
> by using *cmake*, I successfully configured and built gdal-3.4.3, but
> failed to install with the following error message. Any suggestions?
> /Installing with make install...
> ========================= Installation results ===========================
> /usr/local/bin/cmake -S....../GDAL -B....../GDAL/build
> --check-build-system CMakeFiles/Makefile.cmake 0
> /usr/local/bin/cmake -E cmake_progress_start
> ....../GDAL/build/CMakeFiles ....../GDAL/build//CMakeFiles/progress.marks
> make -f CMakeFiles/Makefile2 all
> make[1]: Entering directory '....../GDAL/build'
> make -f CMakeFiles/generate_gdal_version_h.dir/build.make
> CMakeFiles/generate_gdal_version_h.dir/depend
> make[2]: Entering directory '....../GDAL/build'
> cd ....../GDAL/build && /usr/local/bin/cmake -E cmake_depends "Unix
> Makefiles" ....../GDAL ....../GDAL ....../GDAL/build ....../GDAL/build
> ....../GDAL/build/CMakeFiles/generate_gdal_version_h.dir/DependInfo.cmake
> --color=
> make[2]: Leaving directory '....../GDAL/build'
> /usr/local/bin/cmake -DSOURCE_DIR=....../GDAL
> -DBINARY_DIR=....../GDAL/build -DGDAL_SHA1SUM= -DGDAL_RELEASE_DATE= -P
> -- Found Git: /usr/bin/git (found version "2.34.1")
> CMake Error at
> make[2]: *** [CMakeFiles/generate_gdal_version_h.dir/build.make:73:
> CMakeFiles/generate_gdal_version_h] Error 1
> make[1]: *** [CMakeFiles/Makefile2:4367:
> CMakeFiles/generate_gdal_version_h.dir/all] Error 2
> make[1]: Leaving directory '....../GDAL/build'
> make: *** [Makefile:149: all] Error 2
> **** Installation failed. Aborting package creation.
> Restoring overwritten files from backup...OK
> Cleaning up...OK
> Bye./
> Cheers
> On Wed, May 11, 2022 at 12:25 PM Pei JIA <jp4work at gmail.com> wrote:
> Hi, all:
> install it on Ubuntu 22.04, with gcc-11.2,
> /➜ ~ uname -r
> 5.15.0-27-generic
> ➜ ~ lsb_release -a
> Release: 22.04
> Codename: jammy
> ➜ ~ gcc --version
> There is NO
> PURPOSE./
> but failed to install with the following error message. Any
> suggestions?
> "Unix Makefiles" ....../GDAL ....../GDAL ....../GDAL/build
> ....../GDAL/build
> --color=
> CMake Error at
> make[2]: ***
> Cleaning up...OK
> Bye./
> Cheers
> Pei JIA, Ph.D.
> Email: jp4work at gmail.com
> cell in Canada: +1 778-863-5816
> cell in China: +86 186-8244-3503
> Welcome to Vision Open
> http://www.visionopen.com
> Pei JIA, Ph.D.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20220511/75d7ab52/attachment-0001.htm>
