[gdal-dev] Installing drivers on macOS Monterey v12.4
adamgutonski adamgutonski at protonmail.com
Sun May 22 05:19:11 PDT 2022
Hello,
I am having trouble installing gdal with the FileGDB driver in a conda environment. I believe the issue is the version of macOS.
System specs:
- macOS Monterey v12.4
- Apple M1 Pro chip
- 16gb RAM
Attempts so far:
- Tried using osgeo4mac, the formulae appear to be broken on M1 Mac, not sure if there’s a macport for this specific repo.
- Tried using Kyngchaos complete GDAL build, does not cooperate with conda environments
- Tried manually, Conda install -c condo-forge gdal, then copy over the lib files into /anaconda/envs/testing/lib, and copied the include files into /anaconda/envs/testing/include
- Additionally, tried copying the files into the gdalplugins folder located in the lib folder
- Tried installing lib/include files to /usr/local/lib and /usr/local/include
Are there any tips for creating a successful conda build in this mac environment?
Kind regards,
Adam Gutonski
Sent with [ProtonMail](https://protonmail.com/) secure email.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20220522/9934f08b/attachment.htm>
