[gdal-dev] ogr2ogr Postgres upload performance
Alexandre Gacon
alexandre.gacon at gmail.com
Mon May 23 07:38:59 PDT 2022
I will try this way. To turn of SI creation : *SPATIAL_INDEX*=NONE
Le lun. 23 mai 2022 à 15:15, Jan Heckman <jan.heckman at gmail.com> a écrit :
> Perhaps the spatial index update (in de DB) slows the insertion.
> It might be more efficient to not create the SI in the first run,
> then insert more rows and create the SI after all is done.
> I don't know how to turn off SI creation in the command line.
> On Mon, May 23, 2022 at 3:04 PM Alexandre Gacon <alexandre.gacon at gmail.com>
> wrote:
>> Hello,
>> I am using ogr2ogr to upload data from several geopackages to a postgis
>> database. Some tables contain thousands of rows (buildings for example).
>> The import of the first file is quite fast (tables are created for the
>> first file so PG_USE_COPY is used) but the following file is much slower
>> (using INSERT instead of COPY).
>> How could I data insertion for the other files? Force PG_USE_COPY ?
>> Increase the value of GT ? Postpone spatial index creation ?
>> Should I concatenate all the geopackages first and then insert the data
>> in Postgis?
>> Thank you for your help
>> Alexandre Gacon
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/gdal-dev
Alexandre Gacon
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20220523/6844e331/attachment.htm>
