[gdal-dev] ogr2ogr Postgres upload performance
Bo Victor Thomsen bo.victor.thomsen at gmail.com
Mon May 23 10:42:58 PDT 2022
Hi Alexandre -
I made a DOS script ages ago to try the different use cases. It's
inserted as text below. It doesn't test every setup combination, only
the most pertinent.
The base gpkg layer is all the buildings i Denmark, ca. 5.8 million objects.
For my layer I had the following results:
 1. PG_USE_COPY yes: 182 secs.
 2. PG_USE_COPY yes,  -gt 10000000 (5.8 mill. objects in single
    transaction) : 181.5 secs.
 3. PG_USE_COPY yes,  -gt 10000000, UNLOGGED ON, SPATIAL_INDEX NO : 152
    secs.
 4. PG_USE_COPY no : 15 min.
So the "PG_USE_COPY yes" is crucial and using unlogged tables and no
spatial index reduces the time with an extra 30 sec. But you have to
build a spatial index afterwards.
Using insert commands is an obvious "no-no"
As far as I remember, I used the "PG_USE_COPY no" option without any
other refinements. But I didn't append data to an existing table. YMMV
@echo on
set pgclientencoding=UTF-8
set cc= ogr2ogr -progress -lco OVERWRITE=YES -lco SCHEMA=fot -a_srs
EPSG:25832 -nlt PROMOTE_TO_MULTI -f "PostgreSQL" PG:"host=localhost
port=5432 user=xxx password=yyy dbname=zzz" d:/tmp/geodanmark.gpkg bygning
echo %time%
%cc% --config PG_USE_COPY yes -nln bygning1
echo %time%
%cc% --config PG_USE_COPY yes -gt 10000000 -nln bygning2
echo %time%
%cc% --config PG_USE_COPY yes -gt 10000000 -lco UNLOGGED=ON -lco
SPATIAL_INDEX=NO -nln bygning3
echo %time%
%cc% --config PG_USE_COPY no  -nln bygning4
echo %time%
pause
Med venlig hilsen / Kind regards
Bo Victor Thomsen
Den 23-05-2022 kl. 15:03 skrev Alexandre Gacon:
> Hello,
> I am using ogr2ogr to upload data from several geopackages to a
> postgis database. Some tables contain thousands of rows (buildings for
> example).
> The import of the first file is quite fast (tables are created for the
> first file so PG_USE_COPY is used) but the following file is much
> slower (using INSERT instead of COPY).
> How could I data insertion for the other files? Force PG_USE_COPY ?
> Increase the value of GT ? Postpone spatial index creation ?
> Should I concatenate all the geopackages first and then insert the
> data in Postgis?
> Thank you for your help
> Alexandre Gacon
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20220523/ab07a423/attachment.htm>
