[gdal-dev] Command line /python syntax differences
Chris Smemoe
csmemoe at aquaveo.com
Wed Nov 2 09:46:43 PDT 2022
Jonas,
I think your formatting of the arguments is not correct. There are lots of ways to do what you need to do. You can just use your commandline options directly in the python gdal.Translate options or you can call gdal_translate directly using the python subprocess.call command. There are plenty of examples if you just search for it. I think you can just do something like this for what you need:
from osgeo import gdal
ds = gdal.Warp(out_path+’tmp.tif’, [‘I:\\indata\\VPDsc\\VPD_scalar.tif’], options=’-s_srs EPSG:4326 -t_srs EPSG:32628 -overwrite -tr 20 20 -wm 9000 -multi -r near -te 453123 1702425 454123 1703425 -te_srs EPSG:32628’)
See the documentation sent earlier. Also, this example might help you:
https://gis.stackexchange.com/a/380429/53019
Regards,
Chris
From: gdal-dev [mailto:gdal-dev-bounces at lists.osgeo.org] On Behalf Of Jonas Ardö via gdal-dev
Sent: Wednesday, November 02, 2022 8:30 AM
To: Even Rouault; gdal-dev at lists.osgeo.org
Subject: Re: [gdal-dev] Command line /python syntax differences
Thanks Even,
Still some discrepancy.
Python (don't work but no error and no output ):
src_ds = gdal.Open("I:\indata\VPDsc\VPD_scalar.tif")
#1 GDALWARP to warp all bands in one go
options = gdal.WarpOptions(options=srcSRS="EPSG:4326", dstSRS="EPSG:32628", xRes=20.0, yRes=20.0, resampleAlg="bilinear", format='GTiff', outputBounds=[453123, 1702425, 454123, 1703425])
newfile = gdal.Warp(out_path+"tmp.tif", src_ds, options=options)
Command line work ok:
gdalwarp -s_srs EPSG:4326 -t_srs EPSG:32628 -overwrite -tr 20 20 -wm 9000 -multi -r near -te 453123 1702425 454123 1703425 -te_srs EPSG:32628 /cygdrive/i/indata/VPDsc/VPD_scalar.tif /cygdrive/i/data/SNDHR/VPDsc/VPD_scalar_test.tif
Assuming using -te_srs and -t_srs are redundant?
("outputBoundsSRS – SRS in which output bounds are expressed, in the case they are not expressed in dstSRS")
Regards
/Jonas
On 02/11/2022 12:03, Even Rouault wrote:
Jonas,
The doc is at:
https://gdal.org/api/python/osgeo.gdal.html#osgeo.gdal.TranslateOptions
Even
Le 02/11/2022 à 11:53, Jonas Ardö via gdal-dev a écrit :
Dear gdal-gurus,
I am new to using gdal via Python.
As the command line arguments/keywords differ from command prompt mode and Python-mode (for example for example is -r in gdal_translate the same as resampleAlg in gdal.Translate in Python).
I find it tricky to find arguments/keywords in Python.
How can all options/full syntax for gdal-pythons commands be listed as done here <https://gis.stackexchange.com/questions/352643/gdal-translate-in-python-where-do-i-find-how-to-convert-the-command-line-argum> ?
Where they also refer to https://gdal.org/python/ <https://gdal.org/python/> which do not exist.
Any other (full/completed) online resource for this?
Can "pydoc -g osgeo" be used?
Are the The gdal-dev Archives searchable?
Regards
/Jonas, Lund University, Sweden
gdal-dev mailing list
https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
Jonas Ardö
Physical Geography and Ecosystem Science
Lund University
Sölvegatan 12 22362 Lund Sweden
+46462224031
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20221102/ffa999bb/attachment-0001.htm>
