[gdal-dev] Call for discussion: RFC88: Use GoogleTest framework for C/C++ unit tests
Frank Warmerdam
warmerdam at pobox.com
Sun Nov 20 17:07:35 PST 2022
Even,
I'm not a huge GoogleTest fan but then I'm also not saying it *worse* than
any alternative, but the reasons are reasonably convincing, and I'm happy
if those running and contributing tests are happy!
Should I understand from the RFC that
https://github.com/rouault/gdal/tree/gtest implements the migration? (ie.
we have already done the work to migrate, we just need to agree on it?)
Best regards,
Frank
On Fri, Nov 18, 2022 at 2:27 PM Javier Jimenez Shaw <j1 at jimenezshaw.com>
wrote:
> I am not in the PSC, but this RFC sounds very good. Thanks!
> Now that the tests are going to change, maybe it is a good idea to apply
> clang-format to them.
> .___ ._ ..._ .. . ._. .___ .. __ . _. . __.. ... .... ._ .__
> Entre dos pensamientos racionales
> hay infinitos pensamientos irracionales.
> On Wed, 16 Nov 2022 at 20:28, Kurt Schwehr <schwehr at gmail.com> wrote:
>> I am +1 for this switch, but I'm definitely biased by working at Google.
>> My thoughts:
>> tut definitely gets the job done, but I found it a bit awkward too. But
>> I think the updates and the additional features of GoogleTest are probably
>> worth it. I especially like the distinction between ASSERT.* that
>> immediately stops a test when it finds and issue and EXPECT that lets the
>> test move forward until the end of that test so that I can see all of the
>> results of EXPECTS. The formerly separate "mock" capabilities are really
>> handy too.
>> I wrote a bunch of C++ GDAL tests using GoogleTests in the 2013-207 time
>> frame (Even used a bit of that work as starters to the tests in PROJ, but
>> he went way beyond what I had). I have a lot of the tests in github, but
>> they are written against very old versions of GDAL. And, the GoogleTest
>> ability to work with newer versions of C++ has gotten a lot stronger.
>> C++17 wasn't even available when I wrote a lot of the test code. We have
>> been upgrading GDAL and improving the tests, so if there is interest, I can
>> try to do some updates to the repo. If any of the autotest2 code is used,
>> the license should be switched from Apache 2.0 to the MIT style license mentioned
>> here
>> <https://github.com/OSGeo/gdal/blob/a394f9cb299b2c3c2159098483d1fece3a464fda/LICENSE.TXT#L15>
>> https://github.com/schwehr/gdal-autotest2/tree/master/cpp
>> -Kurt
>> On Wed, Nov 16, 2022 at 10:42 AM Even Rouault <even.rouault at spatialys.com>
>> wrote:
>>> Hi,
>>> As this is RFC season. I've prepared RFC88: Use GoogleTest framework for
>>> C/C++ unit tests
>>> Text at https://github.com/OSGeo/gdal/pull/6720
>>> Summary:
>>> The document proposes and describes conversion of the existing C/C++
>>> autotest suite to use the `GoogleTest
>>> framework <https://github.com/google/googletest>`__.
>>> GoogleTest is a popular and maintained framework for C/C++ test
>>> writing, that is a better replacement for the `TUT framework
>>> <https://github.com/mrzechonek/tut-framework>`__ that we use currently.
>>> Even
>>> http://www.spatialys.com
>>> My software is free, but my time generally not.
>>> gdal-dev mailing list
>>> gdal-dev at lists.osgeo.org
>>> https://lists.osgeo.org/mailman/listinfo/gdal-dev
I set the clouds in motion - turn up | Frank Warmerdam,
light and sound - activate the windows | +1 650-701-7823
and watch the world go round - Rush | Geospatial Software Developer
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20221120/b6b64318/attachment.htm>
