[gdal-dev] Why does an old Python code using /vsicurl?[options] syntax yield HTTP 404 now?
Daniel Evans
daniel.fred.evans at gmail.com
Mon Oct 10 01:02:09 PDT 2022
Hi Jukka,
Can you, or the original poster, give some more information on what Python
and GDAL versions you're using that cause trouble? I've not immediately hit
404 errors on trying - with CPL_DEBUG=ON, I can see GDAL successfully
opening tiles (HTTP 206).
With something like 13,000 tiles in a single VRT, and a flakey academic
data server (according to a reply on the linked post), I'm not yet
convinced that the problem is definitively GDAL-specific.
Regards,
Daniel
On Mon, 10 Oct 2022 at 07:47, Rahkonen Jukka <
jukka.rahkonen at maanmittauslaitos.fi> wrote:
> Hi,
> See this question
> https://gis.stackexchange.com/questions/442512/python3-download-soilgrid-http-error
> where the user is obviously trying to use the code from
> https://git.wur.nl/isric/soilgrids/soilgrids.notebooks/-/blob/master/markdown/webdav_from_Python.md.
> The tutorial is well written and I believe that it has been working 2 years
> ago but now it yields a HTTP 404 Not found response from the server. The
> URL to the data is OK and gdalinfo can access the data.
> -Jukka Rahkonen-
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20221010/d3e71308/attachment.htm>
