[gdal-dev] Why does an old Python code using /vsicurl?[options] syntax yield HTTP 404 now?
Daniel Evans daniel.fred.evans at gmail.com
Mon Oct 10 01:03:01 PDT 2022
(To follow my own advice, I've tried with a fresh environment with GDAL
3.4.1 and Python 3.9!)
On Mon, 10 Oct 2022 at 09:02, Daniel Evans <daniel.fred.evans at gmail.com>
wrote:
> Hi Jukka,
> Can you, or the original poster, give some more information on what Python
> and GDAL versions you're using that cause trouble? I've not immediately hit
> 404 errors on trying - with CPL_DEBUG=ON, I can see GDAL successfully
> opening tiles (HTTP 206).
> With something like 13,000 tiles in a single VRT, and a flakey academic
> data server (according to a reply on the linked post), I'm not yet
> convinced that the problem is definitively GDAL-specific.
> Regards,
> Daniel
> On Mon, 10 Oct 2022 at 07:47, Rahkonen Jukka <
> jukka.rahkonen at maanmittauslaitos.fi> wrote:
>> Hi,
>> See this question
>> https://gis.stackexchange.com/questions/442512/python3-download-soilgrid-http-error
>> where the user is obviously trying to use the code from
>> https://git.wur.nl/isric/soilgrids/soilgrids.notebooks/-/blob/master/markdown/webdav_from_Python.md.
>> The tutorial is well written and I believe that it has been working 2 years
>> ago but now it yields a HTTP 404 Not found response from the server. The
>> URL to the data is OK and gdalinfo can access the data.
>> -Jukka Rahkonen-
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20221010/51af23b0/attachment-0001.htm>
