[gdal-dev] Set a PNG background transparent without flip
liglio.pessoal at nexxa.com.br liglio.pessoal at nexxa.com.br
Mon Oct 10 08:08:09 PDT 2022
I want to set an image PNG background to transparent. I do using gdalwarp,
but the image flips horizontally.
I am using a workaround, executing the gdalwarp command twice to flip back.
Can I set the background to transparent using just one command without flip
IMAGE ORIGINAL:
Driver: PNG/Portable Network Graphics
Files: 2022-09-25--18_46_27.png
Size is 400, 400
Metadata:
  NODATA_VALUES=0 0 0
Image Structure Metadata:
  INTERLEAVE=PIXEL
Corner Coordinates:
Upper Left  (    0.0,    0.0)
Lower Left  (    0.0,  400.0)
Upper Right (  400.0,    0.0)
Lower Right (  400.0,  400.0)
Center      (  200.0,  200.0)
Band 1 Block=400x1 Type=Byte, ColorInterp=Red
  NoData Value=0
  Mask Flags: PER_DATASET NODATA
Band 2 Block=400x1 Type=Byte, ColorInterp=Green
  NoData Value=0
Band 3 Block=400x1 Type=Byte, ColorInterp=Blue
  NoData Value=0
COMMAND:
gdalwarp -of PNG -overwrite  -srcnodata 0 -dstalpha -to
IMAGE MODIFIED (Background transparent and flipped)
Files: MI-2022-09-25--18_46_27.png
       MI-2022-09-25--18_46_27.png.aux.xml
Size is 400, 400
Origin = (0.000000000000000,400.000000000000000)
Pixel Size = (1.000000000000000,-1.000000000000000)
  INTERLEAVE=PIXEL
Corner Coordinates:
Upper Left  (       0.000,     400.000)
Lower Left  (   0.0000000,   0.0000000)
Upper Right (     400.000,     400.000)
Lower Right (     400.000,       0.000)
Center      (     200.000,     200.000)
  Mask Flags: PER_DATASET ALPHA
Band 4 Block=400x1 Type=Byte, ColorInterp=Alpha
Regards,
Liglio
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20221010/a2211fef/attachment.htm>
