[gdal-dev] Does it hurt to *always* use BIGTIFF when using gdal_translate
Even Rouault
even.rouault at spatialys.com
Wed Oct 12 03:36:02 PDT 2022
Richard,
BigTIFF doesn't have a formal status like classic TIFF, so its adoption
might be lower by non-libtiff-4.0-or-later based software, in
particularly outdated proprietary software.
BIGTIFF=IF_SAFER could be a reasonable compromise (BIGTIFF=IF_NEEDED is
the default behaviour, but not super appropriate when compression is used)
Even
Le 12/10/2022 à 11:51, Richard Duivenvoorde a écrit :
> Hi Devs,
> In QGIS we have a GUI for gdal_translate, the "Georeferencer".
> It was reported that when Georeferencing huge Tiffs (user was talking
> about 8GB), that QGIS ended up with a broken 3.99GB Tiff, see
> https://github.com/qgis/QGIS/issues/47362
> One of the 'easy' solutions (on QGIS side) would be to *always* add
> the BIGTIFF=yes option.
> Question to you: would that hurt anybody? Is creating a BIGTIFF maybe
> not preferable because of technical or user limitations?
> Thanks for any pointers, or feel free to add it to the issue above.
> Regards,
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
