[gdal-dev] Does it hurt to *always* use BIGTIFF when using gdal_translate
Andrea Giudiceandrea andreaerdna at libero.it
Wed Oct 12 04:47:58 PDT 2022
Il 12/10/2022 11:51, Richard Duivenvoorde ha scritto:
> One of the 'easy' solutions (on QGIS side) would be to *always* add
> the BIGTIFF=yes option.
Hi all,
while there are also the IF_NEEDED and IF_SAFER values for the BIGTIFF
creation option, another possibility would be to have an option to let
GDAL to retry to create the raster file as a BIGTIFF if the the normal
TIFF creation fails or to let QGIS to inform the user if the normal TIFF
creation fails and then offer the possibility to retry using the
BIGTIFF=YES option.
Regards.
Andrea
