[gdal-dev] Does it hurt to *always* use BIGTIFF when using gdal_translate
thomas bonfort thomas.bonfort at gmail.com
Wed Oct 12 12:03:30 PDT 2022
this is one of the reasons we built https://github.com/airbusgeo/cogger
(supposing you are creating a tiled tif): first create your tif with your
usual gdal tooling , unconditionally setting bigtiff=yes, and then as a
postprocessing step run cogger on the resulting file. You'll get a COG
which depending on the final output size will be bigtiff if really needed
or a standard tiff if not.
regards,
thomas
Le mer. 12 oct. 2022, 13:59, Andrea Giudiceandrea via gdal-dev <
gdal-dev at lists.osgeo.org> a écrit :
> Il 12/10/2022 11:51, Richard Duivenvoorde ha scritto:
> > One of the 'easy' solutions (on QGIS side) would be to *always* add
> > the BIGTIFF=yes option.
> Hi all,
> while there are also the IF_NEEDED and IF_SAFER values for the BIGTIFF
> creation option, another possibility would be to have an option to let
> GDAL to retry to create the raster file as a BIGTIFF if the the normal
> TIFF creation fails or to let QGIS to inform the user if the normal TIFF
> creation fails and then offer the possibility to retry using the
> BIGTIFF=YES option.
> Regards.
> Andrea
> gdal-dev mailing list
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20221012/b942129a/attachment.htm>
