[gdal-dev] Transformations with same horizontal datum but different geoid outputs the same Z value
Even Rouault
even.rouault at spatialys.com
Mon Oct 17 03:28:39 PDT 2022
Diogo,
There are far more CRS definitions in the PROJ database, mostly coming
from the EPSG dataset, than there are known transformations from/to
those CRS to other ones
> Genoa 1942 height (Italy)
> $echo "14.995 37.755 3357" | PROJ_NETWORK=ON gdaltransform --debug on -s_srs"EPSG:4326+3855" -t_srs"EPSG:32632+5214"
> >> 1028333.73796622 4195591.29690422 3357
In that situation, "projinfo -t EPSG:32632+5214 -s EPSG:4326+3855
--spatial-test intersects" shows a potential transformation, but that
requires that you need to get (buy) the geo_igm_mar06.grd grid which
does the "ETRS89 to Genoa 1942 height" transformation from
https://www.igmi.org/en and convert it into a format understood by PROJ
> N2000 (Finland)
> $echo "25.15296 62.50195 269" | PROJ_NETWORK=ON gdaltransform --debug on -s_srs"EPSG:4326+3855" -t_srs"EPSG:3067+3900"
> >> 404861.868388335 6931460.32557422 269
There's no known transformation between N2000 and ETRS89 or WGS84 in the
database.
That said
https://www-maanmittauslaitos-fi.translate.goog/kartat-ja-paikkatieto/asiantuntevalle-kayttajalle/koordinaattimuunnokset/fin2005n00-geoidimalli?_x_tr_sl=auto&_x_tr_tl=en&_x_tr_hl=en-US&_x_tr_pto=wapp
shows that there is a FIN2005N00 geoid model that exists for N2000 <-->
ETRS89, so there's potential if that was registered in EPSG.
That said, if you use the online converted at
https://kartta.paikkatietoikkuna.fi/?lang=en to do the N2000 <-->
ETRS89, you can get the result:
1) Transform from EPSG:4326+3855 to ETRS89 3D
$ echo 25.15296 62.50195 269 | PROJ_NETWORK=ON gdaltransform -s_srs
EPSG:4326+3855 -t_srs EPSG:4939
25.15296 62.50195 287.822128823693
2) Use the online transformer from EUREF-FIN-GRS80h (~= EPSG:4939) to
EUREF-FIN-GRS80 + N2000
==> lat=62.50195 lon=25.15296 H=269.2867
3) Transform fromEUREF-FIN-GRS80 + N2000 to EPSG:3067+3900
$ echo 25.15296 62.50195 269.2867 | PROJ_NETWORK=ON gdaltransform
-s_srs EPSG:4258+3900 -t_srs EPSG:3067+3900
404861.868388335 6931460.32557422 269.2867
> EVRF2007 (Estonia)
> $echo "27.059167 57.714444 318" | PROJ_NETWORK=ON gdaltransform --debug on -s_srs"EPSG:4326+3855" -t_srs"EPSG:3301+5621"
> >> 682284.606829111 6401087.4159131 318
There's only one known transformation between EVRF2007 and ETRS89 or
WGS84, but it is for Slovakia.
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20221017/bafc371c/attachment.htm>
