[gdal-dev] OGR SQL dialect on FlatGeoBuf manipulating timestamps
Trygve Aspenes
trygveas at met.no
Wed Oct 19 11:16:57 PDT 2022
OK, so this is a version thing. I upgraded the gdal version and the
following sqlite3 version 3.39.3 then unixepoch works(using the SQLITE
dialect)
ogrinfo -dialect SQLITE -sql "select * from li_flatgeobuf_demo where
unixepoch(TimeStamp) between unixepoch('2013-06-20T17:00:29Z') and
unixepoch('2013-06-20T17:00:29Z')+300" /data/mapserver/tile-index/*
INFO: Open of `/data/mapserver/tile-index/points-20130620070000.fgb'
using driver `FlatGeobuf' successful.
layer names ignored in combination with -sql.
Layer name: SELECT
Geometry: Point
Feature Count: 17
Extent: (7.254900, -6.423300) - (58.263300, 51.656400)
Layer SRS WKT:
GEOGCRS["WGS 84",
ENSEMBLE["World Geodetic System 1984 ensemble",
MEMBER["World Geodetic System 1984 (Transit)"],
MEMBER["World Geodetic System 1984 (G730)"],
MEMBER["World Geodetic System 1984 (G873)"],
MEMBER["World Geodetic System 1984 (G1150)"],
MEMBER["World Geodetic System 1984 (G1674)"],
MEMBER["World Geodetic System 1984 (G1762)"],
MEMBER["World Geodetic System 1984 (G2139)"],
ELLIPSOID["WGS 84",6378137,298.257223563,
LENGTHUNIT["metre",1]],
ENSEMBLEACCURACY[2.0]],
PRIMEM["Greenwich",0,
ANGLEUNIT["degree",0.0174532925199433]],
CS[ellipsoidal,2],
AXIS["geodetic latitude (Lat)",north,
ORDER[1],
AXIS["geodetic longitude (Lon)",east,
ORDER[2],
USAGE[
SCOPE["Horizontal component of 3D system."],
AREA["World."],
BBOX[-90,-180,90,180]],
ID["EPSG",4326]]
Data axis to CRS axis mapping: 2,1
Geometry Column = GEOMETRY
TimeStamp: String (0.0)
OGRFeature(SELECT):0
TimeStamp (String) = 2013-06-20T17:00:29Z
POINT (11.3157 -5.3703)
Trygve Aspenes
ons. 19. okt. 2022 kl. 14:10 skrev Trygve Aspenes <trygveas at met.no>:
> Hi
> I have some FlatGeoBuf files I have generated with the python fiona
> library. This is a lat lon point and a timestamp. So I want to filter by
> timestamp. What I have come up with is to use gdal sql dialect like this:
> ogrinfo -sql "select * from flatgeobuf_demo where
> TimeStamp>='2013-06-20T17:00:29Z'" flatgeobuf-data/*
> INFO: Open of `flatgeobuf-data/points-20130620070000.fgb'
> Layer name: flatgeobuf_demo
> Geometry: Point
> Feature Count: 17
> Extent: (-55.071900, -57.866400) - (58.263300, 51.737400)
> Layer SRS WKT:
> GEOGCRS["WGS 84",
> CS[ellipsoidal,2],
> ORDER[1],
> ORDER[2],
> USAGE[
> AREA["World."],
> ID["EPSG",4326]]
> Geometry Column = _ogr_geometry_
> OGRFeature(flatgeobuf_demo):19
> <truncated>
> However what I want is to make a query with all points between one
> timestamp and another. And here is my problem: the time parameters come
> from a request query and have the format YYYY-mm-ddTHH:MM:SSZ. So I need a
> way to say:
> ogrinfo -sql "select * from flatgeobuf_demo where TimeStamp between
> '2013-06-20T17:00:29Z' and '2013-06-20T17:00:29Z'+TimeInterval"
> flatgeobuf-data/*
> I could rewrite the flatgeobuf file setting TimeStamp as a float
> containing the epoch instead. But then I can not convert the incoming query
> with the time from my request( with fixed format)
> Any idea if, and hopefully how, I can achieve this in OGR SQL?
> Trygve Aspenes
> Trygve Aspenes - Senioringeniør/Senior Engineer
> Fjernmåling Utvikling/Remotesensing development Telefon/Phone: 22963133
> Fjernmålingsavdelingen/Remotesensing department Postboks 43, Blindern
> Metklim 0313 OSLO
> Meteorologisk Institutt
> /Norwegian Meteorological Institute NORWAY
Metklim 0313 OSLO
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20221019/0f816578/attachment.htm>
