[gdal-dev] gdal_calc output to multiband nedcdf ?
Jonas Ardö
jonas.ardo at nateko.lu.se
Thu Oct 20 11:06:34 PDT 2022
Dear gdal-gurus,
Trying to use*gdal_calc* to do the same calculation for tow 366 band
(daily data) files and store it in a *.nc file with the same dimensions
as the input files.
This works OK (output to 366 tiff files):
for i in {1..366} # One band per day output to tif
do
gdal_calc.py --calc="exp( (17.625*D) /(243.04+D) ) / exp(
(17.625*T)/(243.04+T) ) * 100" --outfile=Rh_2020_day$i.tif -D
DPTa_dayavg_C_2020.nc -T Ta_dayavg_C_2020.nc --D_band=$i --T_band=$i
done
This do not work (output to one netcdf file):
do
(17.625*T)/(243.04+T) ) * 100" --outfile=Rh_2020.nc -D
done
yields:
Error! Output exists, but is the wrong geotransform. Use the
--overwrite option to automatically overwrite the existing file
Any suggestions how to make the output into a 366-band netcdf file?
using on Cygwin: gdalinfo.exe --version GDAL 3.5.1, released 2022/06/30
Regards /Jonas, Lund University, Sweden
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20221020/972147e5/attachment.htm>
