[gdal-dev] ogr2ogr doesn't connect to MS SQL Server
Reetz, Michael (NLPV)
Michael.Reetz at nlpvw.niedersachsen.de
Sun Oct 23 23:25:44 PDT 2022
Hi Andrea,
maybe it would be sufficient to add that file. But, unfortunately, I don’t have any privileges to write to that folder or to install any software. I always have to make a request to our IT-department which is a very time consuming procedure. For good reasons “normal” users are not allowed to install software or even run portable versions of applications. Greetings from EMOTET and Co. 😉
Best regards
Michael
Von: gdal-dev <gdal-dev-bounces at lists.osgeo.org> Im Auftrag von Andrea Giudiceandrea via gdal-dev
Gesendet: Freitag, 21. Oktober 2022 12:12
An: gdal-dev at lists.osgeo.org
Betreff: Re: [gdal-dev] ogr2ogr doesn't connect to MS SQL Server
ACHTUNG!! Diese E-Mail erreicht Sie von einem Absender außerhalb der niedersächsischen Landesverwaltungs-Infrastruktur mit TLS-Verschlüsselung. Bitte klicken Sie auf keine Links oder öffnen Sie keine E-Mail-Anhänge, falls Sie den Absender nicht kennen und nicht wissen, ob der Inhalt sicher ist.
Il 21/10/2022 11:48, Reetz, Michael (NLPV) ha scritto:
Since the GDAL/ogr MS SQL Server driver is obviously missing on my computer, I will see if I can get a complete installation of the current GDAL package. This would be very helpful in many situations, especially in scripts that perform transformation tasks.
Hi Michael,
doesn't adding the ogr_MSSQLSpatial.dll file to the "\apps\gdal\lib\gdalplugins\" folder (or installing the gdal-mss package through OSGeo4W Setup) makes the MSSQLSpatial GDAL/OGR driver available to be used with ogr2ogr?
Best regards.
Andrea
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20221024/c5f80f3f/attachment.htm>
