[gdal-dev] Documentation of .gfs file format
Even Rouault
even.rouault at spatialys.com
Tue Oct 25 11:07:37 PDT 2022
Johannes,
You have a number of .gfs templates file in
https://github.com/OSGeo/gdal/tree/master/data
Otherwise just read the code of GMLFeatureClass::InitializeFromXML() if
you want to have the full view of what the GFS reader understand:
https://github.com/OSGeo/gdal/blob/master/ogr/ogrsf_frmts/gml/gmlfeatureclass.cpp#L456
which is the ultimate authoritative source. That said a .xsd file for
.gfs could be useful, if that's something you'd be willing to contribute.
Even
Le 25/10/2022 à 15:16, Johannes Echterhoff a écrit :
> Hello,
> The documentation of the GML driver on
> https://gdal.org/drivers/vector/gml.html has two sections that
> describe the .gfs file format to some extent (section “Syntax of .gfs
> file by example” and section “Advanced .gfs syntax”). When looking for
> more information about the .gfs format, I came across
> https://github.com/OSGeo/gdal/issues/1138, where <precision> was
> mentioned as an additional element that can be used in .gfs files.
> Is the .gfs. file format documented somewhere in full detail? I would
> like to write .gfs template files, and in order to do so, knowing all
> available elements, options, as well as syntax requirements would be
> great to know. So far, I only came across a number of examples – which
> certainly help – but I would like to consult an authoritative source,
> if there is one.
> Best regards,
> Johannes
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20221025/512e25d4/attachment-0001.htm>
