[gdal-dev] Motion: adopt GDAL 3.5.3RC1 as final 3.5.3 release
Greg Troxel gdt at lexort.com
Thu Oct 27 08:31:27 PDT 2022
the problem is that
  work/gdal-3.5.3/swig/python/extensions/gnm_wrap.cpp
has the same timestamp (in the tar file) as
  work/gdal-3.5.3/swig/include/gnm.i
running
  touch work/gdal-3.5.3/swig/python/extensions/gnm_wrap.cpp
after unpack and before build results in a successful build.
I guess make wants object > source, not >=, which seems fair.
I wonder if gnm.i is itself generated as part of distfile creation, and
if it needs a 'sleep 1', or if this is "git checkout"  followed by 'make
dist' and it's all blazingly fast?
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20221027/4527517a/attachment.sig>
