[gdal-dev] Motion: adopt GDAL 3.5.3RC1 as final 3.5.3 release
Greg Troxel
gdt at lexort.com
Thu Oct 27 10:21:00 PDT 2022
Even Rouault <even.rouault at spatialys.com> writes:
> I indeed see that some generated files have a lower timestamp than
> their .i sources. Probably something due to some files being
> regenerated as identical (apart higher timestamp) to their existing
> versions in git and thus not being committed into git. There is
> nothing new in the generation process related to this, so weird that
> this shows up only now. Or perhaps this has hit in the past unnoticed.
> Anyway I've uploaded updated archives whose only difference is just
> doing "touch swig/python/extensions/*" on top of rc1
> https://download.osgeo.org/gdal/3.5.3/gdal-3.5.3rc2.tar.xz
> https://download.osgeo.org/gdal/3.5.3/gdal-3.5.3rc2.tar.gz
> https://download.osgeo.org/gdal/3.5.3/gdal353rc2.zip
> I've also modified the mkgdaldist.sh to force updating the timestamps
> for future releases
Thanks for the quick turnaround!
I have locally updated pkgsrc to 3.5.3rc2, and both gdal-lib and py-gdal
build fine now.
With those, running autotest from gdal release-3.5 branch (tag
v3.5.1RC1), I get a few failures, but I have no reason to think they are
new or super concerning, and should dig into them myself in the
background (while I also flip pkgsrc to cmake).
FAILED ogr/ogr_gpkg.py::test_ogr_gpkg_14 - assert False == 1
FAILED ogr/ogr_gpkg.py::test_ogr_gpkg_15 - AssertionError: SELECT HasSpatialI...
FAILED ogr/ogr_gpkg.py::test_ogr_gpkg_58 - AssertionError: assert 0 == 1
FAILED ogr/ogr_gpkg.py::test_ogr_gpkg_59 - AssertionError: assert 0 == 1
FAILED ogr/ogr_gpkg.py::test_ogr_gpkg_deferred_spi_creation - AssertionError:...
FAILED ogr/ogr_gpkg.py::test_ogr_gpkg_deferred_spi_update - AssertionError: a...
FAILED gcore/geoloc.py::test_geoloc_fill_line[YES] - AssertionError: assert 2...
FAILED gcore/geoloc.py::test_geoloc_fill_line[NO] - AssertionError: assert 22...
FAILED gcore/tiff_read.py::test_tiff_read_big_strip_chunky_way - assert 38441...
FAILED gcore/tiff_write.py::test_tiff_write_64 - AssertionError: coordinate s...
FAILED gcore/tiff_write.py::test_tiff_write_163 - assert 47600 == 47567
FAILED gcore/vrt_read.py::test_vrt_statistics_and_implicit_ovr_recursion_issue
FAILED gdrivers/gpkg.py::test_gpkg_42 - assert 'sqlite3_exec...module: rtree'...
FAILED utilities/test_ogrinfo.py::test_ogrinfo_fielddomains - AssertionError:...
So I'm good with rc2 being promoted.
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20221027/6ca66e13/attachment.sig>
