[gdal-dev] OpenFileGDB Write Capabilities
Philip J. Orlando Philip.J.Orlando at kp.org
Thu Sep 1 08:46:10 PDT 2022
Hello GDAL Dev Team,
I read that the latest version of the ESRI File Geodatabase (OpenFileGDB) driver now supports write and update access to vector layers of File Geodatabases. This doc page<https://gdal.org/drivers/vector/openfilegdb.html#vector-openfilegdb> mentions that write capabilities are supported within GDAL >=3.6. However, from what I can tell, the latest version of GDAL is only 3.5.1<https://github.com/OSGeo/gdal/releases>. Can you please help clarify if version 3.6 has been released, or if write access is available within a different version?
Being able to write to ESRI FileGeoDatabase via GDAL will help me address this issue with the sf R package<https://github.com/r-spatial/sf/issues/1772>. Any insight is greatly appreciated!
Respectfully,
Philip Orlando
NOTICE TO RECIPIENT:  If you are not the intended recipient of this e-mail, you are prohibited from sharing, copying, or otherwise using or disclosing its contents.  If you have received this e-mail in error, please notify the sender immediately by reply e-mail and permanently delete this e-mail and any attachments without reading, forwarding or saving them. v.173.295  Thank you.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20220901/bce73ad3/attachment.htm>
