[gdal-dev] OpenFileGDB Write Capabilities
Even Rouault
even.rouault at spatialys.com
Thu Sep 1 09:01:54 PDT 2022
Phillip,
The documentation is the one of the master repository, and may thus
refer to still unreleased versions like GDAL 3.6.0 that will be released
around November this year
You can for example use of the Docker images (tags ending by -latest)
referenced at https://github.com/OSGeo/gdal/tree/master/docker to try it
out, or build the master branch from the git repository
Even
Le 01/09/2022 à 17:46, Philip J. Orlando a écrit :
> Hello GDAL Dev Team,
> I read that the latest version of the ESRI File Geodatabase
> (OpenFileGDB) driver now supports write and update access to vector
> layers of File Geodatabases. This doc page
> <https://gdal.org/drivers/vector/openfilegdb.html#vector-openfilegdb>
> mentions that write capabilities are supported within GDAL >=3.6.
> However, from what I can tell, the latest version of GDAL is only
> 3.5.1 <https://github.com/OSGeo/gdal/releases>. Can you please help
> clarify if version 3.6 has been released, or if write access is
> available within a different version?
> Being able to write to ESRI FileGeoDatabase via GDAL will help me
> address this issue with the sf R package
> <https://github.com/r-spatial/sf/issues/1772>. Any insight is greatly
> appreciated!
> Respectfully,
> Philip Orlando
> *NOTICE TO RECIPIENT:*If you are not the intended recipient of this
> e-mail, you are prohibited from sharing, copying, or otherwise using
> or disclosing its contents.If you have received this e-mail in error,
> please notify the sender immediately by reply e-mail and permanently
> delete this e-mail and any attachments without reading, forwarding or
> saving them. v.173.295Thank you.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20220901/79fc195d/attachment.htm>
