[gdal-dev] Understand Why a netCDF4 File Is Not Supported
Scott Smith
scott.smith at open-cosmos.com
Thu Sep 1 09:03:50 PDT 2022
Hi All,
I am trying to work with some SMOS data, specifically the netCDF4 files
from https://smos-diss.eo.esa.int/oads/access/.
Running gdalinfo or gdal_translate using the Docker image
osgeo/gdal:ubuntu-full-latest on these netCDF4 files seems to fail with
ERROR 4: '<file>' not recognized as a supported file format.
Full command and output
docker run -v /local/directory/containing/file/:/mnt/data/
osgeo/gdal:ubuntu-full-latest gdalinfo --debug ON
/mnt/data/SM_OPER_MIR_SMUDP2_20220101T001713_20220101T011034_700_001_1.nc
GDAL_netCDF: driver detected file type=3, libnetcdf detected type=3
GDAL_netCDF: No UNIDATA NC_GLOBAL:Conventions attribute
GDAL_netCDF: var_count = 72
GDAL:
GDALOpen(/mnt/data/SM_OPER_MIR_SMUDP2_20220101T001713_20220101T011034_700_001_1.nc,
this=0x55cdea7bac30) succeeds as netCDF.
GDAL:
GDALClose(/mnt/data/SM_OPER_MIR_SMUDP2_20220101T001713_20220101T011034_700_001_1.nc,
GDAL:
GDAL:
ERROR 4:
`/mnt/data/SM_OPER_MIR_SMUDP2_20220101T001713_20220101T011034_700_001_1.nc'
gdalinfo failed - unable to open
'/mnt/data/SM_OPER_MIR_SMUDP2_20220101T001713_20220101T011034_700_001_1.nc'.
>From this I'm not really able to understand what is wrong with the file.
The file with which I am testing is available here:
https://drive.google.com/file/d/1r4R2gy0w2nyEv1fwmMNNR8CHhwjvayIk/view?usp=sharing
I am trying to figure out what is "wrong" with these files which render
them unreadable by gdal. I have not managed to find much by Googling. I'm
happy to continue investigating if anyone is happy to provide any pointers
to where I should be looking.
Any advice, pointers or help would be greatly appreciated.
Many Thanks
Scott Smith
Open Cosmos
p.s. I'm not sure if this is relevant or helpful, but I have managed to
have some partial success with an older version of gdal and some "single
variable" files I created from the original. Included for information, the
gdal version is GDAL 3.3.2, released 2021/09/01 and a file which worked
with gdalinfo is
This email is private and confidential. If you are not the intended
recipient, do not copy or disclose its content, but please contact the
sender immediately.
Open Cosmos Ltd is a company registered in England
& Wales. Registration number: 09704443. Registered office: Electron
Building, Fermi Avenue, Harwell, OX11 0QR.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20220901/c0108d79/attachment-0001.htm>
