[gdal-dev] Reading shapefile from ZIP archive (c++)
Sharon Eldor
seldor at kinetica.com
Tue Sep 6 08:27:21 PDT 2022
Thanks - so is there a way to list the content of the zip file or do I use
some other tool for that?
On Tue, Sep 6, 2022 at 10:50 AM Daniel Evans <daniel.fred.evans at gmail.com>
wrote:
> Hi Sharon,
> I think all you need to do is define the path to open as:
> '/vsizip//parks-and-recreation-feature-map-d.zip/parks-and-recreation-feature-map/parks-and-recreation-feature-map.shp'
> i.e. defining the filepath as:
> /vsizip/<path to the zip>/<path inside the zip>
> When the zip contains only a single (shape)file at the top level - the case where you've got it working - GDAL automatically determines the file to open.
> Docs at: https://gdal.org/user/virtual_file_systems.html#vsizip-zip-archives
> Cheers,
> Daniel
> On Tue, 6 Sept 2022 at 15:30, Sharon Eldor <seldor at kinetica.com> wrote:
>> Hi,
>> Trying to read shapefiles from a zip archive, I am running:
>> GDALDataset::Open('/vsizip//parks-and-recreation-feature-map-d.zip', GDAL_OF_VECTOR |
>> GDAL_OF_READONLY | GDAL_OF_VERBOSE_ERROR | GDAL_OF_SHARED,
>> NULL, NULL, NULL )
>> When there is a directory in the zip, I get an error:
>> Error: `/vsizip//parks-and-recreation-feature-map-d.zip' not recognized as a supported file format.
>> When the files are not under a directory in the zip (same files), the zip file is read with no error.
>> Attaching 2 files for example.
>> Is there a way to directly read the files from the archive with the directory?
>> Thanks,
>> Sharon
>> *The contents of this email message and any attachments are the property
>> of Kinetica DB, Inc. and may contain confidential or privileged information
>> intended solely for the addressee(s). Unauthorized use of this
>> communication is strictly prohibited and may be unlawful. If you have
>> received this communication in error, please notify the sender by reply
>> e-mail, then delete all copies of the communication and any attachments.*
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20220906/682c639a/attachment.htm>
