[gdal-dev] Reading shapefile from ZIP archive (c++)
Daniel Evans
daniel.fred.evans at gmail.com
Tue Sep 6 08:40:25 PDT 2022
The documentation page I linked to states that VSIReadDir() can be used,
and gives other details on operations that might be relevant (e.g.
distinguishing files vs. directories).
Daniel
On Tue, 6 Sept 2022 at 16:27, Sharon Eldor <seldor at kinetica.com> wrote:
> Thanks - so is there a way to list the content of the zip file or do I use
> some other tool for that?
> On Tue, Sep 6, 2022 at 10:50 AM Daniel Evans <daniel.fred.evans at gmail.com>
> wrote:
>> Hi Sharon,
>> I think all you need to do is define the path to open as:
>> '/vsizip//parks-and-recreation-feature-map-d.zip/parks-and-recreation-feature-map/parks-and-recreation-feature-map.shp'
>> i.e. defining the filepath as:
>> /vsizip/<path to the zip>/<path inside the zip>
>> When the zip contains only a single (shape)file at the top level - the case where you've got it working - GDAL automatically determines the file to open.
>> Docs at: https://gdal.org/user/virtual_file_systems.html#vsizip-zip-archives
>> Cheers,
>> Daniel
>> On Tue, 6 Sept 2022 at 15:30, Sharon Eldor <seldor at kinetica.com> wrote:
>>> Hi,
>>> Trying to read shapefiles from a zip archive, I am running:
>>> GDALDataset::Open('/vsizip//parks-and-recreation-feature-map-d.zip', GDAL_OF_VECTOR |
>>> GDAL_OF_READONLY | GDAL_OF_VERBOSE_ERROR | GDAL_OF_SHARED,
>>> NULL, NULL, NULL )
>>> When there is a directory in the zip, I get an error:
>>> Error: `/vsizip//parks-and-recreation-feature-map-d.zip' not recognized as a supported file format.
>>> When the files are not under a directory in the zip (same files), the zip file is read with no error.
>>> Attaching 2 files for example.
>>> Is there a way to directly read the files from the archive with the directory?
>>> Thanks,
>>> Sharon
>>> *The contents of this email message and any attachments are the property
>>> of Kinetica DB, Inc. and may contain confidential or privileged information
>>> intended solely for the addressee(s). Unauthorized use of this
>>> communication is strictly prohibited and may be unlawful. If you have
>>> received this communication in error, please notify the sender by reply
>>> e-mail, then delete all copies of the communication and any attachments.*
>>> gdal-dev mailing list
>>> gdal-dev at lists.osgeo.org
>>> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20220906/ec74bfc0/attachment.htm>
