[gdal-dev] missing docker images for 3.5.2
Even Rouault
even.rouault at spatialys.com
Wed Sep 14 11:32:32 PDT 2022
Hi Javier,
Le 14/09/2022 à 19:56, Javier Jimenez Shaw a écrit :
> Hi
> There is only "alpine-normal-3.5.2" in docker hub for GDAL 3.5.2:
> https://hub.docker.com/r/osgeo/gdal/tags?page=1&name=3.5
> <https://hub.docker.com/r/osgeo/gdal/tags?page=1&name=3.5>
> but many for 3.5.1 (like ubuntu)
> Is that intentional?
Not really. It has been 2 days that I'm attempting to push the images
generated on my PC on Docker hub, and it fails on the ubuntu-full ones,
with the connection being reset after many hours, probably due to their
"big" size and my connection being too slow on upload, so I keep
re-trying. Not the first time I hit that problem, but here it struggles
more than usual. I should probably get off my procrastination of
upgrading my DSL connection to fiber...
If you have a faster connection and want to help, you need to install
docker buildx (not sure I kept note on that installation process, but I
probably followed what is described at
https://github.com/OSGeo/gdal/tree/master/docker#multi-arch-images) with
linux/amd64 and linux/arm64 backends installed, and then from a checkout
of release/3.5 branch:
./docker/build-all.sh --with-multi-arch --release --tag 3.5.2 --gdal
v3.5.2 --proj 9.1.0 --platform linux/arm64,linux/amd64
Takes ~ 1 day for building everything (the slow part is arm64
crosscompilation)
And then relaunch the above command with --push appended to actually
push to Docker hub (it can be done also in a single step but I prefer
doing in two steps to separate upload issues from build issues)
If you're willing to do that, I can grant you push rights to
Even
http://www.spatialys.com
