[gdal-dev] missing docker images for 3.5.2
Alan Snow alansnow21 at gmail.com
Wed Sep 14 11:54:45 PDT 2022
Have you tried automating it in GitHub actions?
On Wed, Sep 14, 2022, 1:32 PM Even Rouault <even.rouault at spatialys.com>
wrote:
> Hi Javier,
> Le 14/09/2022 à 19:56, Javier Jimenez Shaw a écrit :
> > Hi
> > There is only "alpine-normal-3.5.2" in docker hub for GDAL 3.5.2:
> > https://hub.docker.com/r/osgeo/gdal/tags?page=1&name=3.5
> > <https://hub.docker.com/r/osgeo/gdal/tags?page=1&name=3.5>
> > but many for 3.5.1 (like ubuntu)
> > Is that intentional?
> Not really. It has been 2 days that I'm attempting to push the images
> generated on my PC on Docker hub, and it fails on the ubuntu-full ones,
> with the connection being reset after many hours, probably due to their
> "big" size and my connection being too slow on upload, so I keep
> re-trying. Not the first time I hit that problem, but here it struggles
> more than usual. I should probably get off my procrastination of
> upgrading my DSL connection to fiber...
> If you have a faster connection and want to help, you need to install
> docker buildx (not sure I kept note on that installation process, but I
> probably followed what is described at
> https://github.com/OSGeo/gdal/tree/master/docker#multi-arch-images) with
> linux/amd64 and linux/arm64 backends installed, and then from a checkout
> of release/3.5 branch:
> ./docker/build-all.sh --with-multi-arch --release --tag 3.5.2 --gdal
> v3.5.2 --proj 9.1.0 --platform linux/arm64,linux/amd64
> Takes ~ 1 day for building everything (the slow part is arm64
> crosscompilation)
> And then relaunch the above command with --push appended to actually
> push to Docker hub (it can be done also in a single step but I prefer
> doing in two steps to separate upload issues from build issues)
> If you're willing to do that, I can grant you push rights to
> Even
> http://www.spatialys.com
> My software is free, but my time generally not.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20220914/47691c5a/attachment.htm>
