[gdal-dev] missing docker images for 3.5.2
Even Rouault even.rouault at spatialys.com
Wed Sep 14 12:02:52 PDT 2022
Le 14/09/2022 à 20:54, Alan Snow a écrit :
> Have you tried automating it in GitHub actions?
no. Not sure how doable installing the docker buildx stuff in GHA
workers is, and the builds are probably too long compared to the timeout
of GHA (actually, I see it is 72 hours, but not completely sure that
with 2 or 3? vCPUs cross compilation can be done in < 72 hours)
> On Wed, Sep 14, 2022, 1:32 PM Even Rouault
> <even.rouault at spatialys.com> wrote:
>     Hi Javier,
>     Le 14/09/2022 à 19:56, Javier Jimenez Shaw a écrit :
>     > Hi
>     > There is only "alpine-normal-3.5.2" in docker hub for GDAL 3.5.2:
>     > https://hub.docker.com/r/osgeo/gdal/tags?page=1&name=3.5
>     <https://hub.docker.com/r/osgeo/gdal/tags?page=1&name=3.5>
>     <https://hub.docker.com/r/osgeo/gdal/tags?page=1&name=3.5>>
>     > but many for 3.5.1 (like ubuntu)
>     > Is that intentional?
>     Not really. It has been 2 days that I'm attempting to push the images
>     generated on my PC on Docker hub, and it fails on the ubuntu-full
>     ones,
>     with the connection being reset after many hours, probably due to
>     their
>     "big" size and my connection being too slow on upload, so I keep
>     re-trying. Not the first time I hit that problem, but here it
>     struggles
>     more than usual. I should probably get off my procrastination of
>     upgrading my DSL connection to fiber...
>     If you have a faster connection and want to help, you need to install
>     docker buildx (not sure I kept note on that installation process,
>     but I
>     probably followed what is described at
>     https://github.com/OSGeo/gdal/tree/master/docker#multi-arch-images)
>     with
>     linux/amd64 and linux/arm64 backends installed, and then from a
>     checkout
>     of release/3.5 branch:
>     ./docker/build-all.sh --with-multi-arch --release --tag 3.5.2 --gdal
>     v3.5.2 --proj 9.1.0 --platform linux/arm64,linux/amd64
>     Takes ~ 1 day for building everything (the slow part is arm64
>     crosscompilation)
>     And then relaunch the above command with --push appended to actually
>     push to Docker hub (it can be done also in a single step but I prefer
>     doing in two steps to separate upload issues from build issues)
>     If you're willing to do that, I can grant you push rights to
>     Even
>     http://www.spatialys.com
>     My software is free, but my time generally not.
>     _______________________________________________
>     gdal-dev mailing list
>     gdal-dev at lists.osgeo.org
>     https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20220914/b2a4eb8e/attachment.htm>
