[gdal-dev] [SOLVED] Re: missing docker images for 3.5.2
Even Rouault
even.rouault at spatialys.com
Sun Sep 18 21:04:28 PDT 2022
The images for 3.5.2 are now available:
https://github.com/OSGeo/gdal/tree/master/docker#images-of-releases
Even
Le 14/09/2022 à 19:56, Javier Jimenez Shaw a écrit :
> Hi
> There is only "alpine-normal-3.5.2" in docker hub for GDAL 3.5.2:
> https://hub.docker.com/r/osgeo/gdal/tags?page=1&name=3.5
> <https://hub.docker.com/r/osgeo/gdal/tags?page=1&name=3.5>
> but many for 3.5.1 (like ubuntu)
> Is that intentional?
> Thanks,
> Javier.
> .___ ._ ..._ .. . ._. .___ .. __ . _. . __.. ... .... ._ .__
> Entre dos pensamientos racionales
> hay infinitos pensamientos irracionales.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20220919/4927f217/attachment.htm>
