[gdal-dev] odbc issue
marghez9 at libero.it
Fri Sep 16 03:59:07 PDT 2022
Good morning,
I write because I’ve a big issue. I’m an italian archaeologist and I’m doing a PhD in an archaeological site in Spain. My project was based on doing a gis on this site, but after an year working on it, my Professor told me I need to create an automatic connection between Filemaker and QGIS, otherwise I won’t be allow to continue my Phd, that for me it’s kind of like life and death.
After some months of attempts I was able to connect the softwares through ODBC (but there are some bugs and it works only using some specific versions), but currently only filemaker can dialogue with QGIS but not vice versa. I think that the issue is that ODBC driver that filemaker use for connecting to QGIS is “read only”. I did some attempts also between filemaker and LibreOffice and I’ve the same issue, so I doubt could be that filemaker doesn’t give the permission for driver “writ”.
Anyway I read here (https://gdal.org/drivers/vector/odbc.html?fbclid=IwAR2mUiMTb9hsGLpDdSaSY_qnpny8DUTDKc49WVkPw4yvizBBnPB9JoOByX8#creation-issues) that could be also a QGIS issue, so I want to know what do you think about that and if this problem could be solved implementing that. My PhD is without scholarship (so I’m not paid for this), but I’m so desperate that I’m willing to pay for resolve this problem and, in this cane, I need to know how much would be.
Thank you so much.
Margherita Zannini
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20220916/e934a96a/attachment.htm>
