[gdal-dev] odbc issue
Richard Greenwood
richard.greenwood at gmail.com
Fri Sep 16 17:58:24 PDT 2022
Filemaker is an old proprietary database isn't it? Is there a reason that
you have to use it? QGIS has quite a bit of data processing power built in
and easily connects to many FOSS databases. So I wonder if you might be
better off using something better than Filemaker in the first place. Can
you give us more details?
On Fri, Sep 16, 2022, 5:07 AM Marghe via gdal-dev <gdal-dev at lists.osgeo.org>
wrote:
> Good morning,
> I write because I’ve a big issue. I’m an italian archaeologist and I’m
> doing a PhD in an archaeological site in Spain. My project was based on
> doing a gis on this site, but after an year working on it, my Professor
> told me I need to create an automatic connection between Filemaker and
> QGIS, otherwise I won’t be allow to continue my Phd, that for me it’s kind
> of like life and death.
> After some months of attempts I was able to connect the softwares through
> ODBC (but there are some bugs and it works only using some specific
> versions), but currently only filemaker can dialogue with QGIS but not vice
> versa. I think that the issue is that ODBC driver that filemaker use for
> connecting to QGIS is “read only”. I did some attempts also between
> filemaker and LibreOffice and I’ve the same issue, so I doubt could be that
> filemaker doesn’t give the permission for driver “writ”.
> Anyway I read here (
> https://gdal.org/drivers/vector/odbc.html?fbclid=IwAR2mUiMTb9hsGLpDdSaSY_qnpny8DUTDKc49WVkPw4yvizBBnPB9JoOByX8#creation-issues)
> that could be also a QGIS issue, so I want to know what do you think about
> that and if this problem could be solved implementing that. My PhD is
> without scholarship (so I’m not paid for this), but I’m so desperate that
> I’m willing to pay for resolve this problem and, in this cane, I need to
> know how much would be.
> Thank you so much.
> Margherita Zannini
> gdal-dev mailing list
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20220916/c0236fa3/attachment.htm>
