[gdal-dev] (no subject)
Rahkonen Jukka jukka.rahkonen at maanmittauslaitos.fi
Mon Sep 19 04:25:30 PDT 2022
Read https://www.sqlite.org/wal.html. I suggest to change the journal mode into the default mode before inserting the GPKG file into server. How to: Execute "PRAGMA journal_mode=DELETE". I tested that it will now work:
INFO: Open of `/vsicurl/http://localhost:8060/SuomenHallinnollisetKuntajakopohjaisetAluejaot_2022_10k.gpkg'
      using driver `GPKG' successful.
1: Aluehallintovirasto
2: Valtakunta
3: Maakunta
4: Kunta
If the GPKG file in WAL mode is already placed on the server it might be possible to open it somehow as "immutable". I do not know how to do that with GDAL.
-Jukka Rahkonen-
Lähettäjä: gdal-dev <gdal-dev-bounces at lists.osgeo.org> Puolesta Moises Calzado via gdal-dev
Lähetetty: maanantai 19. syyskuuta 2022 14.08
Vastaanottaja: gdal-dev at lists.osgeo.org
Aihe: [gdal-dev] (no subject)
Hello everyone,
We're performing some tests with ogrinfo trying to read GPKG files, and we're facing some issues executing the command with remote GPKG files in WAL mode. As can be checked in the following command output, ogr fails while reading the file content:
ERROR: Error: Command failed: ogrinfo /vsicurl/MY_FILE_URL has GPKG application_id, but non conformant file extension ERROR 1: unable to open database file: this file is a WAL-enabled database. It cannot be opened because it is presumably read-only or in a read-only directory. ERROR 1: Only read-only mode is supported for /vsicurl
What is strange here is that the same file works correctly if we execute the command using the downloaded file.
Is there any way we can execute the command using a remote file?
Thanks so much in advance,
Kind regards!
Moises Calzado
Support Engineer
(US) +1 917 463 3232 | (ES) +34 911 165 823 | mcalzado at carto.com<mailto:mcalzado at carto.com>
[https://storage.googleapis.com/carto-it-files/signature/SDSC-2022-NY_Signature-mini.jpg]<https://eur06.safelinks.protection.outlook.com/?url=https%3A%2F%2Fspatial-data-science-conference.com%2F2022%2Fnewyork%2F&data=05%7C01%7Cjukka.rahkonen%40maanmittauslaitos.fi%7C59c27b74927549e7612f08da9a2f47d9%7Cc4f8a63255804a1c92371d5a571b71fa%7C0%7C0%7C637991825108785824%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C3000%7C%7C%7C&sdata=hAhLefsE2N2%2ByrpGgP%2F%2FH1Hwqi9WeTUK6Onk10RkbsM%3D&reserved=0>
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20220919/4a3133e6/attachment.htm>
