[gdal-dev] ogr2ogr error: ERROR 1: Maximum number of characters allowed reached.
Even Rouault
even.rouault at spatialys.com
Tue Sep 20 09:41:30 PDT 2022
Moises,
there's a limit for the maximum size of a line to 1 MB that was added
some time ago (post 3.2.2). I've increased it to 10 million bytes in
https://github.com/OSGeo/gdal/pull/6403 and also added an open option to
make it configurable.
Even
Le 20/09/2022 à 18:06, Moises Calzado via gdal-dev a écrit :
> Hello everyone,
> We're facing some issues working with ogr2ogr in the 3.5.1 version, as
> we've found a dataset that provokes the following error during the
> execution of the following command:
> ogr2ogr -f CSV -skipfailures -makevalid /vsistdout/
> CSV:munic_s_anonymized.csv -simplify 0.00001 -dim XY -t_srs
> EPSG:4326 -lco GEOMETRY=AS_WKT -lco GEOMETRY_NAME=geom -lco
> CREATE_CSVT=YES > test.csv
> The error that is thrown by ogr2ogr is the following one:
> And when it appears, the process stops processing data. We've been
> able to launch the process without any issue on GDAL 3.2.2, so we
> don't know if something has changes or if it's an unexpected
> behaviour. Have you seen a similar error in the latest versions of GDAL?
> If you want to reproduce it there is a link to the file
> <https://drive.google.com/file/d/1nG1kHqG6bLXBV_aOaPreDW4674ufdNjy/view?usp=sharing>
> that provoked this error.
> Thanks so much in advance,
> Kind regards.
> *Moises Calzado*
> Support Engineer
> (US) +1 917 463 3232 | (ES) +34 911 165 823 | mcalzado at carto.com
> <https://spatial-data-science-conference.com/2022/newyork/>
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20220920/df8d188a/attachment.htm>
