[gdal-dev] Convert grid to polygon shapefile
Paul Meems
bontepaarden at gmail.com
Fri Apr 7 02:33:38 PDT 2023
Hello List,
I'm working on a C# application that uses Golden Software Surfer to create
maps, but I also need to export the data to a polygon shapefile.
Unfortunately, Surfer creates a shapefile with shapes on top of each other
instead of inside each other, and Golden Software support couldn't help
with this issue.
I have a grid-file in Surfer Bin Grid format that can be converted to other
raster formats, a border shapefile created using ST_Convexhull, and a text
file indicating the values of the polygons.
[image: image.png]
Can anyone recommend a way to use GDAL/OGR to make a polygon shapefile from
these resources, or suggest an alternative approach?
Regards,
Paul
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20230407/57c9077f/attachment.htm>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20230407/57c9077f/attachment.png>
