[gdal-dev] Problem with file source projection doing a vertical datum reprojection
Even Rouault even.rouault at spatialys.com
Wed Apr 12 02:24:55 PDT 2023
Michael,
it is well possible this might have worked in the past due to slightly
different behavior of GDAL and/or PROJ, but the current behavior seems
consistent to me. You're trying to transform between 2 compound CRS, the
source one with a unknown vertical datum and the target one with EGM2008
height. There's nothing reasonable that PROJ can do regarding the
vertical transformation in that situation, in particular it would be
quite a bold assumption to assume that the source CRS is actually meant
to be refering to ellipsoidal heights.  If you override with -s_srs
EPSG:32617 (or drop REPORT_COMPD_CS=TRUE), then GDAL will auto-promote
the source CRS to a 3D CRS with ellipsoidal heights, which could also be
questionable from a purist point of view, but is the behaviour we have
had for long now.
Even
Le 12/04/2023 à 10:36, Michael Smith a écrit :
> I have a file with a projection shown, using REPORT_COMPD_CS=TRUE of:
> COMPOUNDCRS["WGS 84 / UTM zone 17N + unknown",
>     PROJCRS["WGS 84 / UTM zone 17N",
>         BASEGEOGCRS["WGS 84",
>             DATUM["World Geodetic System 1984",
>                 ELLIPSOID["WGS 84",6378137,298.257223563,
> LENGTHUNIT["metre",1]]],
>             PRIMEM["Greenwich",0,
> ANGLEUNIT["degree",0.0174532925199433]],
>             ID["EPSG",4326]],
>         CONVERSION["UTM zone 17N",
>             METHOD["Transverse Mercator",
>                 ID["EPSG",9807]],
>             PARAMETER["Latitude of natural origin",0,
> ANGLEUNIT["degree",0.0174532925199433],
>                 ID["EPSG",8801]],
>             PARAMETER["Longitude of natural origin",-81,
>                 ID["EPSG",8802]],
>             PARAMETER["Scale factor at natural origin",0.9996,
>                 SCALEUNIT["unity",1],
>                 ID["EPSG",8805]],
>             PARAMETER["False easting",500000,
>                 LENGTHUNIT["metre",1],
>                 ID["EPSG",8806]],
>             PARAMETER["False northing",0,
>                 ID["EPSG",8807]]],
>         CS[Cartesian,2],
>             AXIS["easting",east,
>                 ORDER[1],
>                 LENGTHUNIT["metre",1]],
>             AXIS["northing",north,
>                 ORDER[2],
>         ID["EPSG",32617]],
>     VERTCRS["unknown",
>         VDATUM["unknown"],
>         CS[vertical,1],
>             AXIS["up",up,
>                 LENGTHUNIT["metre",1,
>                     ID["EPSG",9001]]]]]
> When trying to gdalwarp to EGM2008 using gdalwarp -t_srs
> epsg:32617+3855, vertical datum reprojection does not occur unless I
> overwride the source srs with -s_srs epsg:32617. Using GDAL 3.6.2 and
> proj 9.1.1. With proj_debug, I can see that the PROJ_TRACE:
> vgridshift: is not occurring unless the srs is overridden. I’m fairly
> sure that this has worked in the past but I can’t say exactly which
> version. This is an older geotiff that was written about 7 years ago.
> Michael Smith
> US Army Corps / Remote Sensing GIS Center
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20230412/b3ecf260/attachment.htm>
