[gdal-dev] Problem with file source projection doing a vertical datum reprojection
Michael Smith
michael.smith.erdc at gmail.com
Wed Apr 12 02:45:25 PDT 2023
I guess I thought GTIFF_REPORT_COMPD_CS would only change the display
of the output, not change the interpretation of the SRS? I can confirm
that setting GTIFF_REPORT_COMPD_CS=FALSE does indeed allow the
vertical datum reprojection to happen but I guess I have a poor
understanding of just what GTIFF_REPORT_COMPD_CS does.
Mike
On Wed, Apr 12, 2023 at 5:24 AM Even Rouault <even.rouault at spatialys.com> wrote:
> Michael,
> it is well possible this might have worked in the past due to slightly different behavior of GDAL and/or PROJ, but the current behavior seems consistent to me. You're trying to transform between 2 compound CRS, the source one with a unknown vertical datum and the target one with EGM2008 height. There's nothing reasonable that PROJ can do regarding the vertical transformation in that situation, in particular it would be quite a bold assumption to assume that the source CRS is actually meant to be refering to ellipsoidal heights. If you override with -s_srs EPSG:32617 (or drop REPORT_COMPD_CS=TRUE), then GDAL will auto-promote the source CRS to a 3D CRS with ellipsoidal heights, which could also be questionable from a purist point of view, but is the behaviour we have had for long now.
> Even
> Le 12/04/2023 à 10:36, Michael Smith a écrit :
> I have a file with a projection shown, using REPORT_COMPD_CS=TRUE of:
> COMPOUNDCRS["WGS 84 / UTM zone 17N + unknown",
> PROJCRS["WGS 84 / UTM zone 17N",
> BASEGEOGCRS["WGS 84",
> DATUM["World Geodetic System 1984",
> ELLIPSOID["WGS 84",6378137,298.257223563,
> LENGTHUNIT["metre",1]]],
> PRIMEM["Greenwich",0,
> ANGLEUNIT["degree",0.0174532925199433]],
> ID["EPSG",4326]],
> CONVERSION["UTM zone 17N",
> METHOD["Transverse Mercator",
> ID["EPSG",9807]],
> PARAMETER["Latitude of natural origin",0,
> ANGLEUNIT["degree",0.0174532925199433],
> ID["EPSG",8801]],
> PARAMETER["Longitude of natural origin",-81,
> ID["EPSG",8802]],
> PARAMETER["Scale factor at natural origin",0.9996,
> SCALEUNIT["unity",1],
> ID["EPSG",8805]],
> PARAMETER["False easting",500000,
> LENGTHUNIT["metre",1],
> ID["EPSG",8806]],
> PARAMETER["False northing",0,
> ID["EPSG",8807]]],
> CS[Cartesian,2],
> AXIS["easting",east,
> ORDER[1],
> LENGTHUNIT["metre",1]],
> AXIS["northing",north,
> ORDER[2],
> ID["EPSG",32617]],
> VERTCRS["unknown",
> VDATUM["unknown"],
> CS[vertical,1],
> AXIS["up",up,
> LENGTHUNIT["metre",1,
> ID["EPSG",9001]]]]]
> When trying to gdalwarp to EGM2008 using gdalwarp -t_srs epsg:32617+3855, vertical datum reprojection does not occur unless I overwride the source srs with -s_srs epsg:32617. Using GDAL 3.6.2 and proj 9.1.1. With proj_debug, I can see that the PROJ_TRACE: vgridshift: is not occurring unless the srs is overridden. I’m fairly sure that this has worked in the past but I can’t say exactly which version. This is an older geotiff that was written about 7 years ago.
> Michael Smith
> US Army Corps / Remote Sensing GIS Center
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
> http://www.spatialys.com
> My software is free, but my time generally not.
